Recalls On 12 Gt? Suspension Noise In Front
95Nelson
78
DeWitt, MI
Thinking about taking my 12 GT in for some warranty work - my front suspension "klunks" on some downward drops in pavement so I thought I'd check to see if there are any recalls or other issues I should have addressed at this time. Only other problem I've been having is with the my-sync in making & answering calls.
Any info and suggestions are appreciated.
Thanks
I found when I had my iPhone it'd do weird stuff with the sync system. Works a lot better with my Galaxy S3. Just note that if you have more than one app that it selects for something say calling, then it'll have problems. Make the default what you want and you'll be good to go.
Thanks
i have the same noise on my 2012 gt and i replaced the suspension with steeda struts and springs, when i was taking the strut mount off the passenger side it fell apart after removing the nut holding it to the strut. balls from the bearing went everywhere not sure if its the problem but i bought the 2011 gt500 strut mounts and it doesnt do it anymore
