Recommend Radiator Fans?
DJHA90
581
Texas
What is everyone running for a Radiator fan? My Front end got messed up and I need a radiator and Fan. Lots of info on the Radiator choices but not much on the fans. I see Mishimoto fans tie wrapped to Mishimoto radiators -- but I also saw the dual mishimoto fans in an aluminum shroud. Anyone have this? Would fans without the shroud flow more air? Any other good fans.
Thanks
Tom
The shroud helps with sucking more air thru the radiator to cool down the water. If there was no shroud it would be like a leakage and not as much air would be sucked thru the front. I had a 95 with heads and cam and a summit radiator and a stock fan. I had no problems with cooling and I live in Phx. Now I have a 91 with a summit radiator and the same fan and no problems either
