86bluecobra
Advanced Member
OK that mark on the balancer has numbers. When you point the timing light down and look at the balancer you will see what the timing is set to. The pointer off the block is where you will be wanting to look at. It maybe a good idea to jack up the car (put it on jack stands) and crawl under it and have a look at the balancer and the numbers on it. Mark with a white paint marker the 0 mark and the 10 degrees BTDC. This will give you a better visual of where you are when you point the light at it.
