Well I got lucky the guy I bought her from did alot to her and took great care of her. She already has BBK cold air intake, aluminum radiator, under drive pulleys, headers, h-pipe, flow masters, aluminum drive shaft center force clutch, 5.0 short shifter, 3:73 gears, weld drag lites, a pillar gauge pod w temp and oil press. gauges. Since I've had her I purchased a Trick flow track heat upper/lower intake, matching 75 mm throttle body, 90mm maf w calibrated for 24lbs. inject. and the 24s themselves as well. I'm purchasing Trick flow twisted wedge track heat heads, 1.7 rockers as well as a e303cam next so we can install it all at once. Caaaaaaan't wait.
Well the cam is mild I know but I think it will work great for the street and as far as the giggle gas goes.... you never know there might be a S Trim in her near future. My last car was a 93 hatch as well... mostly stock with an Incon twin turbo kit... boost is nice. That car made over 400hp and tq at 12 lbs boost.
One of the better looking foxes ive seen. Looks very nice. Also have you thought any on a cintrif SC? Ive herd good numbers and long life on these old foxes.
