Refilling Steering rack and Pump
I fill it all up without turning the wheels. To do this, I disable the ignition and fill, crank, fill, crank until we're close. Then I put the front end just off the ground and turn the wheels back and forth, almost lock to lock but not quite. Continue to fill as needed (as air bleeds out).
Having the wheels off the ground unburdens the system while you bleed it.
Consider replacing the high pressure and low side lines. THe low side lines are bulk 3/8" line IIRC (be sure you get Power steering/hydraulic line).
Good luck.
i also have to refill my PS system. can i jus turn the pulley by hand to circulate the fluid? Im working by myself so if i could turn pulley and pour at the same time that would be great. Or will turning by hand take hours or days to purge air?:shrug:
oh and is ATF type F recommended? I assume its cheaper than labeled PS fluid?
You only have to turn it by hand until the system will not except all of the fluid in the reservoir. At this point when you start it the reservoir does not empty and air fill the system. Now you let it run and slowly fill the reservoir till it stays full.
As far as fluid, I use what is recommended by the rack manufacturer. I no longer have the Ford rack and the rack manufacturer does not recommend ATF because it damages the seals on their particular rack. So I Just used power steering fluid. Type F is for Ford specific rack the way I see it. So if its a Ford rack then go with Type F.
upon further research... It appears the Power Steering system uses Mercon ATF not
type F as I stated previously... :D
Type F is specified on OEM components on our stangs. What is the source of your info (someone might have decided to supercede Type F in our systems but I'm not aware of it).
FWIW, one of the aftermarket repair manuals I have lists Mercon, though my Ford literature says otherwise.
Well... Now I'm totally confused! :D
Haynes Manual says Mercon...
My Ford owners manual says type F (which I have to go with,right??)
But all I could find the other day was type FA at the parts store... What the heck is that??
Do you think it's Type F compatible??
Man I'm just getting ready to button it up! Help !! :D
Well... This should be the last word on this subject...
The Haynes manual is wrong... Do not use Mercon.
The Ford Mustang Owner Guide is correct (of course). Type F
After receiving much grief at O'Reilly's that I was an idiot for returning Type FA
for Type F. I left with simply a refund ,not wanting to deal with them anymore. :mad:
FWIW... Autozone and O'Reilly are out in my book.
Going to my old standby, Advance Auto, I quickly located on the shelf Castrol Type F
with the exact Ford # in the Owner Guide... ESW-M2C33-F
I Love Advance Auto... Always top name-brand parts, well stocked fluids and knowledgeable CAR people
Everyone else, at least around the my area, has idiots on their staff and
stocks to many cheap parts....
As soon as I calm down, I'm going back out to work on the car.... :D
This project just won't die!
Glad you got it. I went through the same thing awhile back (it made sense that we'd be using Mercon by 1994, but that's not so). I also wondered if half my PS fluid was Mercon from previous owners topping it off (that was one reason I flushed it).
Most of the multi-usage fluids don't lump Type F into their description because Type F has such a high coefficient of friction. Type F also has some different seal compatibility properties.
Chevron also has a Type F available in many parts stores.
