- Apr 8, 2007
- 11
- 0
- 2
Replacing the fuel filter as part of a tuneup on a 1993 Mustang GT but do not have a hand vacuum pump or a fuel pressure gauge and cannot afford to buy them. How can I relieve the fuel system pressure without tools?
I just let the car sit overnight before I change the fuel filter, the pressure is usually alleviated by then.
Tip: before you remove the old filter from the bracket put some vacuum caps on each end of the filter so the fuel wont spill down you arm when you're taking it out.
You dont have a screw-driver? Just takes a Philips head to take off 2 or 3 screws on the plastic trim in the trunk behind the drivers side taillight and unplug the inertia switch and run the car until it dies. You are still going to get fuel coming out of the lines so wear some safety glasses or goggles like stated previously.
