Relieving fuel pressure
on the fuel rail behind the alternator there is a schrader valve. as long as the key is off the pump wont come on. So use a screwdriver and bleed down the pressure. then change the regulator and install the gauge.
no problem... you will find that if you remove the upper intake and take the 2 screws out that hold the fuel rail to the intake that it will bealot easier to remove the fpr.
