remote battery terminal q
DmnStr8
NH
I'm thinking of adding remote battery terminals to by battery relocation and cut off switch project. I figured this was a good idea, since the trunk's key hole had been shaved and if my battery went dead I was basically SOL.
I'm going to put the terminals behind the license plate with the cut off switch. But I wanted to check my plan with the more knowledgeable amongst us.
I was thinking I could wire the positive terminal to the battery side of the switch and just ground the negitive terminal to the best grounding spot near by. Sound good so far?
Ok now because this are is a tight space and for the sake of appearances (no birds nests) I was hoping I could use a smaller gauge of cabling for these terminals then I am using for the rest of the project (1/0). Is that ok. I figure it will only be used for jump starts or charging. Mostly emergency use.
Whats guage do you think would be safe for this application?
Thanks guys.
Rear mounted battery ground wiring. Follow this plan and
you will have zero ground problems.
One 1 gauge or 1/0 gauge wire from battery negative post
to a clean shiny spot on the chassis near the battery. Use
a 5/16” bolt and bolt it down to make the rear ground.
Use a 1 gauge or 1/0 gauge wire from the rear ground
bolt to a clean shiny spot on the block.
One 4 gauge wire from the block where you connected
the battery ground wire to the chassis ground where the
battery was mounted up front. Use a 5/16” bolt and bolt
down the 4 gauge engine to chassis ground, make sure
that it the metal around the bolt is clean & shiny. This
is the alternator power ground.
The computer has a dedicated power ground wire with
a cylindrical quick connect (about 2 ½”long by 1” diameter.
It comes out of the wiring harness near the ignition coil &
starter solenoid (or relay). Be sure to bolt it to the chassis
ground in the same place as you bolted the alternator power
ground. This is an absolute don’t overlook it item for EFI cars
Picture courtesy of timewarped1972
attachment.php
Crimp or even better, solder the lugs on the all the wire.
The local auto stereo shop will have them if the auto parts
store doesn't. Use some heat shrink tubing to cover the lugs
and make things look nice.
For a battery cut off switch, see http://www.moroso.com/catalog/categorydisplay.asp?catcode=42225
is the switch http://www.moroso.com/catalog/images/74102_inst.pdf is the installation instructions.
Use the super duty switch and the following tech note to wire it and you will
be good to go.
Use the Moroso plan for the alternator wiring and you risk a fire. The 10
gauge wire they recommend is even less adequate that the stock Mustang
wiring.
There is a solution, but it will require about 40' of 18 gauge green wire.
Wire the battery to the two 1/4" posts as shown in the diagram.
The alternator requires a different approach. On the small alternator plug
there is a green wire. It is the sense lead that turns the regulator on when
the ignition switch is in the run position. Cut the green wire and solder the 40'
of green wire between the two pieces. Use some heat shrink to cover the
splices. See http://fordfuelinjection.com/?p=7 for some excellent
help on soldering & using heat shrink tubing.
Run the green wire back to the Moroso switch and cut off the excess wire.
Try to run the green wire inside the car and protect it from getting cut or
chaffed. Crimp a 18 gauge ring terminal (red is 18 gauge color code for the crimp
on terminals) on each wire. Bolt one ring terminal to each of the 3/16" studs.
Do not add the jumper between the 1/4" stud and the 3/16" stud as shown it the
Moroso diagram.
How it works:
The green wire is the ignition on sense feed to the regulator. It supplies power
to the regulator when the ignition switch is in the run position. Turn the
Moroso switch to off, and the sense voltage goes away, the voltage
regulator shuts off and the alternator quits making power.
See the following website for some help from Tmoss (diagram designer) &
Stang&2Birds (website host) for help on 88-90 wiring and lots more…
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
Diagram courtesy of Tmoss and Stang&2birds.
Thanks. That sums up all of what I am doing at the moment for my cut off switch.
But...I am adding remote battery terminals to it and wanted to know what guage I needed for these (want to stay as small as safely possiable). Plus I wanted to know if I could just wire the poitive terminal to the battery side of the switch and ground the negitive terminal out to the closest ground.
Thanks.
From my days as an aircraft mechanic, all the external power connections used a 3 prong connector. The power & ground prongs were longer than the 3'rd prong. The 3'rd prong was voltage input to a starter relay that was wired in series with the power input prong. That way when you pushed the power receptacle all the way on the prongs, the 3r'd prong energized the relay and closed the circuit between the power prong and the battery. That prevented anyone from shorting the power and ground prongs and crating a nasty electrical fire.
Do you think I would risk a fire wiring the way I posted? I figure this is just a protection in case my battery goes dead since the oinly way to open the trunk with with the remote release.
There is always a risk anytime you have exposed electrical components. Only you can decide if your particular method covers these components well enough to prevent any hazards.
