Anybody have a remote start installed on a standard? The guy I talked to at the shop said he could do it, but didn't recommend it. What do you guys think?
hognutz said:I will say again I think installing one on a manual is stupid unless you were to design you one trick switch mechanisme that would only allow it to activate in neutral.
Also we bypass the PATS , like you all know it won't start without the key in the ignition(electronic device) so we can bypass it, pretty tricky but it's working perfectly.
wiz said:How do you do that exactly? My guy basically took the chip out of the key and mounted it inside the steering column...which seemed a little sketchy to me...but what else can you do?
KaPPaBaLL said:bunch of crap.. There are alarm systems out there that will start when it's in gear and still not launch foward.
I'm getting mine installed soon.. It basically starts the engine but all the electricals are off.. so no launching foward.
Sam98 said:![]()
What planet are you from? The clutch is mechanical, and the PCM, EFI, fuel pump and ignition are all electrical. You cannot keep the car from lunging forward if the transmission is in gear, and you will never start the car without all of these electrical systems functioning.
hognutz said:I washed my keys by accident one time with my remote start. my car started up and shut off three different times before I figured out wtf was going on.
KaPPaBaLL said:have to be wrong one point in life or another huh? hehe
