REMOVAL OF BUMPERS
fastpony00 said:
Anyone know how you remove the from and rear bumpers off of a 99-02 GT.
Need Help!?$
First!!! - Disconnect the neg side of the battery (SRS!) Wait two minutes before working in the vicinity of the impact sensors.
Then, apply then parking brake, raise the car, use jackstands, etc.
FRONT
1. Working under the car, detach the plastic clips securing the lower edges of the bumper cover.
2. Working in th efront of the wheel opening, detach the retaining screws securing the bumper cover to the inner splash shield.
3. Pry out the lower edge of the splash shield, then reach up behind the bumper and remove the bumper cover to fender retaining nuts.
4. Remove the two retaining rivets securing the upper portion of the bumper cover and pull the bumper cover assembly out and away from the car.
5. Disconnect any electrical connections which would interfere with removal.
6. Remove the bumper retaining bolts and pull the bumper assembly out and away from the car.
REAR
7. Working under the car, detach the plastic clips and screws securing the lower edges of the bumper cover.
8. Working in the trunk, pry out the plastic clips securing the pass side, driver's side, and rear inside trunk finishing panels to allow access to the bumper cover retaining bolts.
9. Detach the retaining nuts securing the bumper cover to the tail light panel and right and left quarter panels. Pull the bumper cover assembly out and away from the car.
10. Remove the bumper retaining bolts and pull the bumper assembly out and away from the car.
Installation on both items is essentially the reverse of the above.
That'll be $10 bucks please... :D :nice:
