Do I need to drain the transmission fluid in order to remove the bell housing from my C4 automatic transmission?
I already removed the six bolts and separated the bell housing from the engine. I assumed that it would be dry similar to removing the clutch from a manual transmission. No fluid spilled out so I believe I was right.
Now I need to remove the seven bolts on the inside of the bell housing aka "Lester" and remove it from the transmission itself.
help / explanation much appreciated
