remove egr
  • Thread starter Thread starter mike allen
  • Start date Start date Apr 5, 2004
M
mike allen
14
camarillo cal
Apr 5, 2004
  • Apr 5, 2004
can I remove the aluminum piece between the t body and the manifold, I am not using the egr?
a_turbo_stang
346
Cincinnati Ohio
Apr 5, 2004
  • Apr 5, 2004
If your not gonna use the EGR then yes you can remove it.
M
mike allen
14
camarillo cal
Apr 5, 2004
  • Apr 5, 2004
What about the throttle linkage, looks like it mounts on that piece ?
W
Weaseled
Daytona Beach
Apr 5, 2004
  • Apr 5, 2004
I'm not using my EGR either, but I've had a problem with one of the delete kits out there.
A while back I bought a Ron Morris EGR delete kit. It is a 1/8" plate that takes the place of the EGR spacer. When I went to install the kit I couldn't bolt my throttle linkage back on because it hit my fuel pressure regulator.
I know Accufab sells a spacer that is stock width. I want to upgrade my 65mm TB to 70mm anyways, so I'm going with the Accufab setup which comes with a EGR spacer that is stock width.
W
Weaseled
Daytona Beach
Apr 5, 2004
  • Apr 5, 2004
I should also add I had this problem with my GT-40 intake and a Downs intake. I tried a 1" spacer, 1/2" spacer and no spacer at all. It just would NOT work.
Engine (EGR Deleted) Solution the hotter combustion chambers?
  • PonyGTrider
  • Jan 21, 2026
  • 3 4 5
4K
Fox 5.0 Mustang Tech May 2, 2026
PonyGTrider
Fox Removing smog only questions
  • 91GTstroked
  • Sep 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
91GTstroked
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
D
Question about EGR valve, replacement, and a part on the valve.
  • DPP
  • May 9, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 23, 2026
DPP
D
Resolved 1999 cobra removed lower intake manifold to crossovertube
  • hvcobra99
  • Sep 6, 2026
  • SVT Tech Forum
SVT Tech Forum Sep 6, 2026
hvcobra99
