I got the bolt on the side off, but there seems to be something else holding it on. I want to put some tweeters in place of those horrible sounding 3.5s, but I really dont want to take the dash apart to do it
I usually use a flat stubby screwdriver and place it between the cover and the dash about 1" from the edge next to the top of the dash. If it was the drivers side, it would be to the right edge of the cover and the left edge of the dash. This helps pop that one clip out easier.
The Ford procedure is to put a small hooked tool, that will fit through the grilles into the grille at the top and us it to pull the cover out of the slot at the top. It has some of those metal snap fasteners that go around a plastic tab on it. A tiny screwdriver or bent coathanger works.
They are pretty easy to remove when replacing the speakers. But it was a pain to put the speaker grill back on after I installed a new A-pillar with gauges. I almost decided not to use it.
