Removing `87 Smog pump
  • Thread starter Thread starter M.A.V.
  • Start date Start date Dec 27, 2004
M.A.V.
107
Georgia
Dec 27, 2004
  • Dec 27, 2004
Does anyone know what length belt I would need to run on an `87 5.0 that already as the A/C compressor removed if I remove the smog pump also? In other words , Stock set up but No A/C and no Smogpump.
Thanks
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Dec 27, 2004
  • Dec 27, 2004
Plug the two vacume lines, remove the pump, remove the lines to the back of the heads and plug the heads. Run a shorter belt.
sgarlic
3,085
Dec 27, 2004
  • Dec 27, 2004
I don't know for sure, but it says you need 84.5 with the a/c removed, or 84.5 with the smog pump removed.. it says the stock belt with a/c is 90.5.. so figuring removing each accessory shortens the belt by 6, you'd think you would need a 78.5 belt. Most auto stores are cool with returning belts so long as you don't run the vehicle with the belt on, so if it's not exactly right you could always return it for the correct size.
Anybody know for sure?
Engine Belt routing with supercharger and smog/ac/ps delete
  • Steve6482
  • Jul 15, 2026
Fox 5.0 Mustang Tech Jul 15, 2026
Steve6482
Fox Rear Seat Belts - 87-89 vs 90-93 length
  • dan50
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
Mustang5L5
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Thursday at 3:50 PM
AeroCoupe
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Engine My Gates K060845 (85 1/4”) belt doesn’t fit
  • Mcmahst
  • Jun 26, 2025
Fox 5.0 Mustang Tech Jun 27, 2025
Mcmahst
