  • SN95 4.6L Mustang Tech
Removing 98 4.6L
  • Thread starter Thread starter apats77
  • Start date Start date May 16, 2011
apats77
178
Watertown, MA
May 16, 2011
  • May 16, 2011
Is it possible to remove the engine without removing stock headers?
Also anyone have some tricks or suggestions on taking it out?
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
May 16, 2011
  • May 16, 2011
Yes, I would definitely recommend taking it out with the headers attached. It will make your life much easier. Suggestions on taking it out? Hmm... find someone dumb enough to do it for next to nothing and save yourself the effort. In all seriousness, just take your time and label things as you go.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
May 16, 2011
  • May 16, 2011
drop it out the bottom. literally the fastest way to pull a motor on one of those mustangs. Its how the car was built actually.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
May 17, 2011
  • May 17, 2011
Dropping the Kmember out is definately the fastest way to get the motor out, just remember to plumb the thing when you put it back it. Some people will scribe the possition of the K onto the chassis before they unbolt anything in an attempt to be able to have it go back in the same spot later. I would still check it to make sure it was plumb after.
Screamin' Demon
204
winchester, va
May 17, 2011
  • May 17, 2011
If I have to do it again I will be dropping the entire K member assembly.
We put in my new PI engine, SLP longtubes, ANNNND 4r70w from the top....
WOW. She was tight. Once inside, she fit like a glove and those headers fit amazingly well. They are tight on the trans and Im sure the passenger side will have to be loosened some to pull the transmission seperately.
Back to the subject, yes you can and do it with headers.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
May 17, 2011
  • May 17, 2011
i have dropped the engine on my old car in just under 2 hours out the bottom. that includes removing the s/c.
best bet is to find a friend with a lift!!
L
2003 mustang v6 3.8 fuel issue
  • lacole1
  • Jul 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 26, 2026
apple99Mustangdude
A
R
Interior and Upholstery How to remove seatbelt torx screw
  • Riley Barth
  • Jul 6, 2026
Fox 5.0 Mustang Tech Jul 13, 2026
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
T
Fox *Solved* Motor mount bolt question
  • TDM389
  • Mar 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 22, 2026
TDM389
T
