There are two slip connects, 1/2" & 5/8" below the alternator next to the inner fender. They are the same kind and size connectors used on the fuel lines.
The removal tools look like little plastic top hats, you will need the 1/2" & 5/8" ones. Look in the A/C repair section at your local auto parts store to find them. The hat shaped section goes on facing the large part of the coupling. Then you press hard on the brim until it forces the sleeve into the coupling and releases the spring. You may need someone to pull on the line while you press on the coupling. Put some motor oil on them when you put the line back together.
