Removing AC Condenser??
87lc2
214
Got in a front end collision and the condenser was smashed. im looking to just remove it for the time being and replace it later. however, there are no obvious connections on the line that can just be taken off with a wrench. how do i take it out without damaging the lines so i can put another one on later?
There are two slip connects, 1/2" & 5/8" below the alternator next to the inner fender. They are the same kind and size connectors used on the fuel lines.
The removal tools look like little plastic top hats, you will need the 1/2" & 5/8" ones. Look in the A/C repair section at your local auto parts store to find them. The hat shaped section goes on facing the large part of the coupling. Then you press hard on the brim until it forces the sleeve into the coupling and releases the spring. You may need someone to pull on the line while you press on the coupling. Put some motor oil on them when you put the line back together.
First thing you need to do is have the system evacuated of the refrigerant. I would highly recommend a professional with the right equipment do it unless you like buying the rare and expensive R12 (unless you decide to convert in the process). Keep in mind that whenever you open up the air conditioning system, you must replace the accumulator because the dessicant in the unit will become void of its purpose and you will have much worse problems later.
