Removing air filter from vortech box
  • Thread starter Thread starter sacky07
  • Start date Start date Sep 27, 2011
sacky07
35
  • Sep 27, 2011
Sorry to ask such a stupid question, but i cant seem to find an easy way to remove the air filter from the vortech air box. I know many setups have been switched to cold air in the fender but mine hasnt. I can see my filter and its nasty. Do I need to loosen the clamp and pull the accourdian style tube off the mass air? This is what i have been trying to do but that sucker is glued on there or something. Im afraid Im going to break the mass air try to pry that tube off. Any suggestions? Thanks
VibrantRedGT
"STANGNET'S PENGUIN SMACKER"
424
154
Boca Raton, Florida
Sep 27, 2011
  • Sep 27, 2011
Are you talking about this (see picture)? If so, unclamp the dryer hose from the meter and unhook the connector off the meter itself. Then you can pull the Vortech box, filter, MAF, the entire unit from the car. It's a pain because the box is jammed in there pretty good. Once removed you will see how it's assembled. Basically there is a clamp on the inside of the Vortch box holding the MAF in place. Your best bet is buying a power pipe and getting the MAF / Air Filter in the fender for cooler air (see second picture). UPR plastic power pipe, $115 from Rick91GT here on the forums.
sacky07
35
  • Sep 28, 2011
I cant get the big silicon hose thats at the end of the dryer hose off the meter. Its really stuck. Is there any solvents i can use the help loosen it it up, something that wont harm the meter. Im afraid ill break the meter trying to get the hose off.
  • dan50
  • Jul 18, 2026
dan50
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
Forced Induction Bypass valve backwards?
  • Dontknowchit
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
JD1964
A
SOLD For Sale: 1993 Ford Mustang Cobra Modified
  • anjteal93
  • Sep 5, 2025
2K
Fox Body Mustangs For Sale (1979-93) Oct 26, 2025
Mindseye007
Forced Induction Vortech correct filler tube routing
  • nicholase
  • May 21, 2024
Fox 5.0 Mustang Tech May 21, 2024
nicholase
