  • SN95 4.6L Mustang Tech
removing air silencer
  • Thread starter Thread starter laser2kgt
  • Start date Start date May 1, 2004
L
laser2kgt
237
Laredo, TX
May 1, 2004
  • May 1, 2004
http://www.mustangworld.com/ourpics/fcar/intke.htm <--- does this also apply to the newer gen stangs (99+)? i own a 00' and im thinking of removing the air silencer. is this actually worth it? some people say yes, others say no. better or worse for the performance? wut should i do?
chevylover
190
Castro Valley, CA originally St. James Missouri
May 1, 2004
  • May 1, 2004
Yes, I have a 99 and I took mine off. It's more of a snorkle than a silencer. Sucking air straight from the fender. I didn't really notice any extra noise, but then again I'm running 2 chamber flows and might not be able to hear it
propellerhead
1,541
&quot;but what's with the but shots?&quot;
May 1, 2004
  • May 1, 2004
I have an 04. I plan on shortening it only. Not totally removing it. I don't want it sucking hot air from the engine bay.
I plan on doing it for the sound. Any performance increase will be negligible.
28
  • May 1, 2004
It's the first thing I did to my 2004 gt. I drove the mustang to about 500 miles and then took off the silencer.
It may be in my head but it sounded better and seemed to pull harder.
I wouldn't put it back on.
chevylover
190
May 1, 2004
  • May 1, 2004
Your right about the performance being negligible but the only time you'll be sucking hot air from the engine bay is driving around town and anywhere under 35 mph. Above that your pushing enough air through the grill to keep it flushed out.
When I take mine to Infineon I'll pull the pass. side headlight and give it a direct shot to the fresh air
propellerhead
1,541
May 1, 2004
  • May 1, 2004
Hmmm... good point. Now you got me thinking.
T
Tampa04GT
50
  • May 2, 2004
I just did the test of removing the little snorkle from the stock MAS air ...
My 04 GT was stock except, yesterday I had an off road H pipe put on with 2 chamber flows.. and first thing I noticed was a drop in idle power for some reason i guess the back preasure droped with the new exhaust poor engine was starving for more air.. :-(.... when I would go to take off in first it would kind of stumble almost stall then cetch on and take off... since I removed the snorkle 4 mins ago I ran it ... runs better taking off in first between 1000-2000 rpms is alittle bit quicker at WOT .....and sounds somewhat deeper at idle.
Seems to rev a tab bit faster too no huge changes though like a set of gears would feel like.
So until I get a MAF and new TB and plenum I guess this will do...
Thanks for the info
Dave
L
license2ill
223
  • May 2, 2004
Just go ahead and cut away the entire airbox. The whole notion of sucking "cold air" into your engine is a joke and a half. What you really want if anything is lesser restriction.
decoy562
1,526
Acworth, GA
May 2, 2004
  • May 2, 2004
I took mine out, but then put it back in because my car was idling funny without the silencer on.
L
laser2kgt
237
Laredo, TX
May 3, 2004
#10
  • May 3, 2004
  • #10
took it off. feels stronger at higer speeds. sounds a lil different too.
Modular2v
3,222
23
99
oklahoma
May 3, 2004
#11
  • May 3, 2004
  • #11
more of a gurgling sound with it off
  • Gulftown980x
  • Jul 29, 2026
squeak93
For Sale 3-owner 1987 Mustang GT, $18K obro, Lancaster CA
  • Bill Cool
  • Oct 6, 2024
2K
Fox Body Mustangs For Sale (1979-93) Oct 13, 2024
nickyb
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
98 GT PI Swapped Engine Fires, Dies Immediately NOT PATS
  • MMccPerformance
  • Dec 2, 2023
2K
SN95 4.6L Mustang Tech Dec 20, 2023
Yel2002GTAuto
Y
J
  • JRC99
  • Apr 19, 2025
JRC99
J
