  • 1994 - 1995 Specific Tech
Removing Distributor
  • Thread starter Thread starter SN95StangMan
  • Start date Start date Aug 10, 2004
SN95StangMan
1,292
Lynwood, CA
Aug 10, 2004
  • Aug 10, 2004
What do I have to do to get the distributor out. I see what some tab with a bolt on it that looks like it is the only thing holding it down. Do I just unscrew that, mark everything, and pull out?
I searched, but you can't search for "distributor"
Joes95GT
3,132
Delaware
Aug 10, 2004
  • Aug 10, 2004
Undo the distributor bolt. Remove the cap. Make sure to mark the place of the rotor when you remove the distributor, or else you could be in trouble.
Remember, when the distributor is out of the motor, DO NOT turn the motor over.
Joe
SN95StangMan
1,292
Lynwood, CA
Aug 10, 2004
  • Aug 10, 2004
Cool, thanks.
194stang
148
  • Aug 10, 2004
distributor
A small piece of advice.....when you pull the dist out,pull it as straight up as possible and then look down hole to make sure oil pump drive didnt fall out of pump.....dosnt usally happen but it can.
WhiteDevil
2,717
San Diego
Aug 10, 2004
  • Aug 10, 2004
I always rotate my motor to TDC #1 cylinder before i pull it out. Its a million times easier that way.
194stang
148
  • Aug 10, 2004
yup....agree with setting to TDC.....good advice
94TURBO5 O
2,509
VA
Aug 10, 2004
  • Aug 10, 2004
Yes make sure you are @ TDC before you pull it out.
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
R
Microsquirt tune for stroked 351W in a foxbody
  • roldy
  • Jul 26, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Oct 25, 2026
roldy
R
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
  • brandyn200
  • Jun 20, 2026
AeroCoupe
