I am installing a mechanical autometer gauge, how do you get this thing off? I've tried unscrewing it but it just spins and spins. Am i missing something here?
Thanks
Thanks
Mavrick said:Mechanical gauges have no sender to depend on, and you get readings whether the car is ON or OFF, whereas with electronic gauges you need power from the ignition to turn the gauges on.
TIMMY2734 said:umm, car has to be running to get oil pressure................
Sweet.Mavrick said:Ya, i bought my gauges used from a guy in PA. Nice guy, sent me the adapter fitting for the temp gauge, fittings and copper line for the oil gauge!
89sleeper said:Sweet.I had to buy mine when I ordered them from Summit. A lot of people just order the gauge and not the adapters and then get upset when they don't just hook right up.
It would be impossible for the water gauge.evn_05 said:Be sure and use PLENTY of teflon tape on the T fitting that you put on there. I guess we didnt get enough on mine cause I noticed it was coverd in oil when i was changing my oil. Just another thing I need to fix....
Well good luck and make sure your connections on the gauges are good I wouldnt want to have hot oil/water spraying out in the cockpit.
