removing old pinstriping
  • Thread starter Thread starter lqqknloh
  • Start date Start date Dec 28, 2003
L
lqqknloh
  • Dec 28, 2003
how can i remove pinstriping (the stick on kind)that has been on my car since shortly after the car was purchased in 1988.these are 9 pinstripes that run along the body moulding down both sides of the car.the stripes are really baked on there from years of sun.i think if i try to pick at them with like a fingernail or something they will pull the paint up with them.they are stuck on that bad.any good ideas will be greatly appreciated because i would really like them off. thankyou.
MustangPunk302
1,051
West Michigan
Dec 28, 2003
  • Dec 28, 2003
I used a razor blade and very very carefully picked away till I could pull it off. It shouldn't pull the paint up, I polished the car afterwards and you can't tell it was ever there.
BigDaddyCee
1,404
Canada
Dec 28, 2003
  • Dec 28, 2003
You also might want to try a product called "Goo-Gone" it is made to dissolve adhesive residue and won't hurt the paint it is at the hardware store in the paint or cleaner section. You may want to try a hairdryer or a heat gun on low to soften the pinstripe first then use the razor blade tecnique as mentioned above. That is how I did mine.
L
lqqknloh
  • Dec 28, 2003
thanks for the help. ill try the goo gone and then soften them up with a hairdryer.
DirtyD916
804
Norcal 916
Dec 28, 2003
  • Dec 28, 2003
itll look better
mike keirstead
1,121
ROLLING A JOINT
Dec 28, 2003
  • Dec 28, 2003
Yes use a hair dryer or you will be taking paint with them. And that me sanding to get it right again.
TRWXXA
190
RIGHT BEHIND YOU!!!... Made you look.
Dec 29, 2003
  • Dec 29, 2003
Don't use a razor blade. If you're not careful you could scratch or gouge the paint.
Take your time, and work on about 6-10 inches of a stripe at a time.
Heat the stripe a bit with a heat gun (use the 'low' setting) to soften it, then gently scrape it off with the edge of a soft plastic scraper -- like the ones used for applying Bondo.
Use Goo-Gone to help get off the real stubborn pieces. It is likely the stripes will be brittle, so you probably won't be able to just pull an entire stripe off all at once.
Plan on doing it in stages. It sounds like you have a lot of stripes, and you will get tired of working on it. Expect the paint under the stripes to be a bit darker than the rest of the car due to fading or other discoloration.
Polish the car up afterwards.
N
needforspeed440
49
  • Dec 29, 2003
Use hot water, or the goo gone stuff. hair dryer may not work on really old ones. NO RAZOR BLADES!
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
M
Progress Thread mkk50's Progress Thread
  • mkk50
  • Aug 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 22, 2025
Progress Thread The Mach Returns - Update/build thread
  • squeak93
  • Feb 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Friday at 8:00 PM
squeak93
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
