Removing rust
  • Thread starter Thread starter farmboy89
  • Start date Start date Sep 1, 2008
F
farmboy89
38
  • Sep 1, 2008
What is the best chemical way to remove large areas of rust... such as the roof of a car.... I need some way to chemically remove a very large area of rust, that will still support a paint job afterwards
crane550
122
  • Sep 1, 2008
I hear of rust converters, but I imagine these will only work on the surface. Your problem remains underneath. Your going to want to sand, grind, and scrape off any rust that you have until your at un affected metel. Else your going to just postpone your problem. I recommend a wire wheel or heavy duty sand blaster.
If there are any better chemical solutions I would love to know about it.
Platonic Solid
1,960
CT-USA
Sep 2, 2008
  • Sep 2, 2008
Any Phosphoric Acid based metal etching product.
wild70stang
317
  • Sep 2, 2008
I have heard of this stuff works, thought I have never used it.
Behr.com: Products - Concrete & Masonry Cleaner/Etcher No. 991-N
65fastbackresto
1,229
AR
Sep 2, 2008
  • Sep 2, 2008
I used Metal Ready
made by POR15, they got a website.
67rcks
373
Sep 3, 2008
  • Sep 3, 2008
sandblasting or wire wheel until you see no rust in pores. I would not use anything chemical that promises "to react with rust" or similar. All the manufacturers recommend applying PE-based putties on clean metal to get the best adhesion (you will get to it later).
Hack
1,945
Minneapolis
Sep 3, 2008
  • Sep 3, 2008
I would be very nervous about sandblasting or wire wheeling a large thin piece of sheet metal like a roof. It's really easy to warp metal with either method. Consider checking with a pro locally.
Platonic Solid
1,960
CT-USA
Sep 3, 2008
  • Sep 3, 2008
PPG sells Phosphoric Acid as Deruster P800-127 which is similar to Por15 Metal Ready.
C
coogs
  • Sep 8, 2008
Swimming pool acid cut with water. Rubber gloves and scotchbrite pad.
Finish with "Ajax" cleanser and water. Dry it good and coat with epoxy primer
like SPI's stuff.
Platonic Solid
1,960
CT-USA
Sep 8, 2008
#10
  • Sep 8, 2008
  • #10
like SPI's stuff.
Swimming pool acid ( A.K.A. Muriatic Acid, A.K.A Hydrochloric acid ) is quite effective, but it leaves a salt deposit (which the Ajax cleanser is probably/hopefully removing.)
Phosphoric Acid leaves a rust inhibiting zinc oxide coating
Jester67
908
TN
Sep 8, 2008
#11
  • Sep 8, 2008
  • #11
Rust Converter - Eastwood Rust Treatment & Prevention Products
Works well
C
Chudik
55
#12
  • Sep 8, 2008
  • #12
You can use wire wheeling or sender …
K
Door post and rust repair
  • Kleinjj27
  • Aug 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 8, 2026
Kleinjj27
K
Paint and Body Cowl Pan
  • jeremyzcook82
  • Sep 13, 2026
Fox 5.0 Mustang Tech Saturday at 3:10 PM
Rcdgl
R
1990 Mustang with no-start condition - Fixed and how-to
  • TTSaleen
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 22, 2026
TTSaleen
F
Electrical Foxbody wiring harness 2.3 to v8 swap
  • Foxbodyjake
  • Mar 23, 2026
Kleinjj27
K
Rust under side window weatherstrip
  • swe13
  • Jun 5, 2025
2005 - 2014 S-197 Mustang -General/Talk- Jun 5, 2025
swe13
