I have a bone stock engine, no smog addons seeing as how I live in AL. they are not needed, no a/c, and now I want to know if I can remove my egr valve and block off the hole?
Phatt_daddy said:I have a bone stock engine, no smog addons seeing as how I live in AL. they are not needed, no a/c, and now I want to know if I can remove my egr valve and block off the hole?
Phatt_daddy said:Why do I want to remove it? Let me see, well since the car came from a meth head that thought he could work on cars the wiring was butchered. After I fixed that when I pulled the engine, I figured out that it wasn't working. How did I figure it out? When I pulled it off the intake pure gas poured out of it then I checked it along with my haynes manual. No dice, acording to them it ain't working. So I figured that if it ain't working then why have it taking up weight? I know it is only ounces, but when the driver weighs in at 260 plus change, every little bit helps. Also it is a little pricey to take the chance at it not helping out on the gas milage.
So what do yall suggest? Keep it and also replace the O2 sensors along with the MAP and IAC? or forget all and carb with a stock 4brl intake and a Holley 4brl? Car gets like 10-12 mpg right now and it is my dd. This is getting expensive and in about three weeks I will be doing one of the two. Oh yea, to carb all I need to buy is the carb, regulator, some line, and the air cleaner. Do the math and give me some suggestions.
Thanks,
Nate.
Phatt_daddy said:Well after some serious figuring, I have decided that yall are right. From a cost perspective, it will be "cheaper" for me to stay with the efi by about $100.00.and that was with me replacingiac valve, egr valve, 2 oxy sensors, tps, map sensor, new short belt, both heater hoses, lower rad hose, water pump, and a speedo cable. Still came out about a hundred cheaper. Looks like I will stay injected.
Nate
darthcual said:I have my EGR blocked as stated above but have had none of the ill symtoms that yall have described. I get 15mpg city and 20mpg hiway and thats on the original O2 sensors that have 100k on them. A couple of my buddies also w/ fox stangs have blocked theres with no regrets. Guess we're just lucky?!
