removing the steering rack
  • Thread starter Thread starter gabe3586
  • Start date Start date Dec 31, 2005
gabe3586
40
  • Dec 31, 2005
Well im trying to change my oil pump with the motor in the car and came across a problem. I dont have enough clearance for the pan to come out unless I pull the steering rack. I took the two big nuts off the front and the little one right near the left nut. My question is, what else do I have to take off to remove the rack?
Thanks, Gabe
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 31, 2005
  • Dec 31, 2005
Remove the two long bolts that go through the rubber bushings that mount the rack assembly to the chassis. Then remove the two bolts that hold the steering shaft flex coupling together. Then you can pull the rack assembly down and out of the way.
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
G
79 steering rack problems
  • garyrc
  • Mar 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 8, 2026
AeroCoupe
Suspension 87 steering wheel slightly wobbles after new Rag joint install
  • R82148V
  • Jun 16, 2025
Fox 5.0 Mustang Tech Jun 24, 2025
R82148V
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Take a look at my rack!
  • bicknell
  • Sep 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2025
Willybill32
