  • SN95 4.6L Mustang Tech
Removing UD Pullies/Auto
  • Thread starter Thread starter 3ponyshow
  • Start date Start date Jul 8, 2004
3ponyshow
319
Las Vegas
Jul 8, 2004
  • Jul 8, 2004
Alright guys. Nothing in the search has this one and I need help.
I'm installing a Mongoose kit so I have to remove my Steeda UD Pulleys. According to the directions, it's a little different for an automatic. It says to remove the plug in the front of the trans and hold the torque converter with a 14mm socket.
I found and removed the plug, felt the 14mm bolt, put on the socket, but it just falls off when I turn the crank. What am I not getting here?
J
jc315
21
Fayetteville, NC
Jul 8, 2004
  • Jul 8, 2004
Your doing this with two ppl right I just put mine on my auto it was a two man job. Get your buddy to hold the 14mm wrench on the torque converter while you hit it with the breaker bar. Hope that helps.
Defleshed
Satanic Mechanic
Nov 30, 2003
10,569
In Torment, In Hell
Jul 8, 2004
  • Jul 8, 2004
ahh dude, I just made a thread about this!!
http://forums.stangnet.com/showthread.php?t=480169&highlight=holding+torque+converter
make sure you read the entire thread, because the guy at the very bottom who posted twice was the answer i was looking for. worked fine for me, and I didnt need two people. Put the screwdriver up there, held it with one hand, and with the other, i twisted the crank ever so softly until the screwdriver was hard in place, then i wailed on the crank, and all was better.
Teen'93stang5.0
3,560
813
Jul 8, 2004
  • Jul 8, 2004
whats the mongoose kit?
Defleshed
Satanic Mechanic
Nov 30, 2003
10,569
In Torment, In Hell
Jul 8, 2004
  • Jul 8, 2004
i think its a supercharger kit. I've breifly heard about it, but it didnt stick in my memory. I hear its good though.
3ponyshow
319
Las Vegas
Jul 8, 2004
  • Jul 8, 2004
Yep. Supercharger system also known as the Cobra Killer from T&J Performance. Check it out.
http://www.modularfordpowerhouse.com/
Defleshed. Thanks for the heads up! There are two windows. One is on the bottom of the bell housing. (That appears to be the one you were using) The other is in the front of the transmission a little higher up on the driver's side. (That's the one I was trying to use). I'll try it out tomorrow.
Defleshed
Satanic Mechanic
Nov 30, 2003
10,569
In Torment, In Hell
Jul 8, 2004
  • Jul 8, 2004
cool dude. just for the record, to get the pulley OFF i used a 2 prong gear puller. The harmonic balancer puller (the one with the three screws) just wasnt working for me. The screws kept warping and bending horribly. I was afraid (terrified) to snap one off. The 2 prong gear puller was straight forward, less bolt torquing, fit right on and yanked that crank pulley right off, no questions asked. See, now typically, I have to do things a different way that recommended, because when I'm working on cars, everything that can go wrong, does.
3ponyshow
319
Las Vegas
Jul 10, 2004
  • Jul 10, 2004
Thanks all for the help. Worked like a charm!
T
What's it Worth? 2002 GT conv/auto
  • tonydetesta
  • Jan 7, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jan 21, 2026
Mustang5L5
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
M
Progress Thread mkk50's Progress Thread
  • mkk50
  • Aug 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 22, 2025
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
For Sale 3-owner 1987 Mustang GT, $18K obro, Lancaster CA
  • Bill Cool
  • Oct 6, 2024
2K
Fox Body Mustangs For Sale (1979-93) Oct 13, 2024
nickyb
