Take a thick philips screwdriver, a hammer, a few wrenches, and a sharp prybar or chisel. Cut all the rivots off of the window motor and the regulator. Use the philips to punch out the pinn and then chisel the aluminum rivit off. remove the track bolts. Lift the window assembly until the rivots come to the top of the door. past the belt strip. Do the same on the two rivots connecting the window to the regulator. I have done this before in like ten minutes at a junk yard for some dummies who thought they should buy the whole door instead of ripping it apart. I guess they were going to take it back to the crib and use the torch. DUH. So its easy if you knock out all the rivots. PM me if you need more info.
CB
