Replaced ect sensor, chopppy in low rpms.
acuna88
So I have an 88Gt and it was running rich and getting 11 mpg and it would run real choppy under 2k rpms and not accelerate until it hit the the 2k. So I did some research and figured it might be the ect sensor, so I went ahead and replaced it and cleaned the throttle body while I was there. Now it's worse, its alot choppier I don't know if its choking or running lean. Any Ideas? Thanks in advance.
It would reset the codes...so you now might not have any stored. You'll have to drive for a little bit before running them.
'88's don't have a check engine light that works, unless you have a cali mass air car. So no idea if there is a code stores.
Biggest reasons for poor fuel ecomomy and poor running...o2 sensors. EGT can also play a role in that. But run the codes before tossing money around blindly
Ok so I pulled the codes and i got 11 (two blinks) then i think another 11 or a 12? I couldn't get it to flash again. Also could the distributor be knocking it off because is seems to be choking, when i push the gas about halfway down it'll choke and struggle to accelerate.
was that KOEO(Key on engine off) or KOER(Key on engine running)?? or both??
I tried key off and got nothing then i tried key forward and thats when i got the flashes. Then i tried it with the engine running and got nothing. I'm thinking about replacing my spark plug wires with a set of ford racing wires, right now its using bosch wires. I checked the spark plugs, they're ACDelco, i doubt that's helping. Also thinking about replacing the O2 sensors, think that should do it? Thanks.
