  • 1994 - 1995 Specific Tech
Replaced switch, still no A/C
  • Thread starter Thread starter 94v6GT
  • Start date Start date Aug 5, 2008
9
94v6GT
141
  • Aug 5, 2008
went and bought a refill w/ gauge kit. gauge said it was full so i replaced the low pressure switch at firewall. now i see/hear compressor kick on for 1 second then off for 3 continuously.
gauge will show pressure waaaaay high!, until compressor kicks in then it drops way low.
what now
F
fish254
237
Brooklyn NY
Aug 5, 2008
  • Aug 5, 2008
those refill gauges dont work i had the same problem u dont have enough gass for the compressor to kick on!!
HISSIN50
34
129
Aug 5, 2008
  • Aug 5, 2008
Agreed. For the low pressure reading to be valid, it has to be viewed after the compressor has been engaged for a few seconds.
9
94v6GT
141
  • Aug 5, 2008
so its still low then? ok i'll try adding. i jus didnt wanna risk anything (mainly my safety)
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Aug 5, 2008
  • Aug 5, 2008
Chances are it's still low. Once the pressure equalizes across the high and low sides, the low pressure switch turns the compressor off. You can jumper the terminals in the harness to force it to run, so that it will accept more refrigerant.
HISSIN50
34
129
Aug 5, 2008
  • Aug 5, 2008
If you don't want to risk your safety, have a shop check it over.
Always use proper manifold gauges (they're accurate and allow you to see high-side pressure, which is huge).
If you are concerned about the mass of charge, post up your low and high side pressures, along with ambient temps.
Good luck.
9
94v6GT
141
  • Aug 6, 2008
I proceeded to empty most of the bottle into the system. the compressor continued to cycle on and off, but the A/C does blow cool now?
the gauge alternated between 45-50(off) and 25(on). i would guess ambient was around 70-75 degrees but the engine was warming(idleing 10-15 minutes)
I think the system at some point stopped accepting refrigerant. it blew the hose out of the fitting between the gauge and the bottle so i will probably jump the switch to keep it cycled 'on' and hopefully a fresh bottle will get it icey.
If these gauges are ineffective ($20 for bottle w/ guage) do i just continue filling until the compressor 'stays' on??
HISSIN50
34
129
Aug 6, 2008
  • Aug 6, 2008
The low side pressure should change when the compressor is engaged (like it will go from 30 to 20 PSI, etc).
Manifold gauges are the only way to really know what's going on. You dont want your high-side reading to be too elevated.
You also don't want to just fill it till the compressor stops cycling. The best way to know what's going on is to measure the mass of refrigerant placed into the system. After that, noting high and low pressures with regard to ambient and vent temps, and using a P-T chart, can get someone close.
9
94v6GT
141
  • Aug 8, 2008
update: so i bought another refill bottle and put about 1/2 of it in. compressor still goes on and off intermitently blow A/C blows icy cold works for me!
D
1999 G/T 4.6 A/C clutch not engaging.
  • David B.
  • Apr 26, 2025
1996 - 2004 SN95 Mustang -General/Talk- May 8, 2025
David B.
D
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
  • dan50
  • Jul 18, 2026
dan50
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
M
  • mnky99
  • Sep 5, 2025
mnky99
M
