Replacing exhaust system
  • Thread starter Thread starter Vatchy
  • Start date Start date Dec 9, 2006
V
Vatchy
10
  • Dec 9, 2006
I'm in the process of replacing my exhaust system and I've run into a slight problem and need some advice. Is there an easy (or even mediumly difficult) way to get the tailpipe hanger out of the rubber mount? I don't want to destroy the mount 'cause I need it to hang the new system. I'm talking about the rod that is attached to the stainless part of the tail pipe immediately in front of the rear bumper.
billison
I like tinted tail
2,607
1,094
184
stl
Dec 9, 2006
  • Dec 9, 2006
when i did mine i just unhooded the muffers, or the tails from the mufflers and worked with it....alot
bubba-dough
1,044
Indiana
Dec 9, 2006
  • Dec 9, 2006
I think you can unbolt the metal part of the hanger at the frame can't you? Its been a while. Or try spraying it with alcohol for a lubricant. Alcohol will not deteriorate it. Thats what we used at the plant to put the rubber grommets on the ac lines. If you do tear the rubber mount up, I bought new ones for my car at Advanced Auto for $3.95 each.
onefstsnake
792
Northern VA
Dec 9, 2006
  • Dec 9, 2006
spray them with WD40
Mine go in and out with ease now.
V
Vatchy
10
  • Dec 10, 2006
Thanks for the replies. I didn't know you could get replacement ones at the parts store. I guess that means that I don't have to worry about them. I guess that means that I can get it finished today.
bubba-dough
1,044
Indiana
Dec 10, 2006
  • Dec 10, 2006
Just make sure your parts store carries them before you tear anything up. They do look slightly different but they worked just fine.
JChalfan
551
Bellevue, WA
Dec 11, 2006
  • Dec 11, 2006
I've always used WD40 too, and it works great. I never considered whether WD40 would cause the rubber to deteriorate, but I've never noticed a problem with it.
Like bubba-dough said, the ones from a parts store probably won't look the same. As long as the holes are right about the same distance apart, they should work fine.
If you're picky, 5.0resto has them:
http://www.latemodelrestoration.com/products.aspx?category=MEXHAUSTAC&page=2
Look towards the bottom of the page.
Jeff
Sicarius428
2,085
Dec 11, 2006
  • Dec 11, 2006
WD40 and dish washing liquid works great to get them in and out. After that, just a bit of muscle, might want to wear some gloves and goggles to protect your hands and dirt and rust getting in your eyes.
Kevin
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
G
1982 Mustang GL 5.0 single to dual exhaust conversion
  • Guyton
  • Jun 27, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 1, 2025
limp
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
M
Too much for me to repair in my current housing situation
  • My Drama Magnet 04 Gt
  • Apr 1, 2026
  • The Welcome Wagon
The Welcome Wagon Apr 14, 2026
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
