Replacing ignition lock - please help!
  • Thread starter Thread starter stanatic
  • Start date Start date Dec 7, 2004
stanatic
259
Los Angeles, CA
Dec 7, 2004
  • Dec 7, 2004
if i move the key around on my 89 stang it will turn off. from what i read on here it sounds like i need to replace the ignition lock. someone mentioned it was a 5 minute job to replace. but can someone please walk me through it? i have no idea how to replace it. please help!! thank you in advance.
HISSIN50
34
129
Dec 7, 2004
  • Dec 7, 2004
turn it to 'run', push the button in and pop it out. install new one and reverse steps.
good luck.
stanatic
259
Los Angeles, CA
Dec 7, 2004
  • Dec 7, 2004
well that sounds easy to do. Thanks!!
HISSIN50
34
129
Dec 7, 2004
  • Dec 7, 2004
it is - post back if something does not go well. if you look at your new switch, you should find a little 'push button' - find it on your old switch and you are good.
good luck.
stanatic
259
Los Angeles, CA
Dec 8, 2004
  • Dec 8, 2004
HISSIN50, i was able to replace it without any problems. Thanks again for the help!!
OL' WHITEY
273
Weddington, NC
Dec 8, 2004
  • Dec 8, 2004
Just a heads up. The lock may not be bad. It could be the actual ignition switch. When my ignition switch went bad, the first symptom was intermittent turn signals and fan operation. I replaced the lock, thinking this would do it. A month or so later, I had the same problems plus, if I jiggled the key a little harder, the car would die. I replaced the ignition switch and have had no more problems at all. Good luck.
stanatic
259
Los Angeles, CA
Dec 8, 2004
  • Dec 8, 2004
well for now my problems have gone away. the key doesn't wiggle anymore and the car doesn't turn off. but you're right about my ignition switch. i did notice that it's going to need replacing as well. the plastic part is separating from the metal part. if i pull down on it just a little it cuts off the power. it looks rather simple to replace so i think i'll be doing that next. thanks for the heads up though!
OL' WHITEY
273
Weddington, NC
Dec 8, 2004
  • Dec 8, 2004
Maybe you can zippy-tie that bad boy tight 'till you get it replaced. When it goes, you stop! Beware!
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
L
2000 Mustang PATS - Broken Key and Wire - HELP!
  • Laree Taylor
  • May 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
manicmechanic007
W
1993 LX 5.0 dies after ignition parts replacement
  • Warhorse85
  • Aug 16, 2025
  • 5 6 7
4K
Fox 5.0 Mustang Tech Nov 4, 2025
General karthief
N
Power door lock motor Question
  • NYFox
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 17, 2026
NYFox
N
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
