1320stang
mudbilly said:one down, one to go........got the drivers side installed in less than an hour..........:SNSign:
but how tight to i tighten everything????????????????
here is a pic with the new spring overlayed on top of the old..
67topless said:... tighten things down loosely and take the car for a leisurely stroll around the block. Then once you got her back in the garage, torque everything down to spec while the car is resting on it's suspension (i.e. tires on the ground). It is a pain, but well worth it. ( I just went through this earlier in the spring and my rear was un-even because I torqued it down with the suspension off the ground.
HTH's
Scott
I needed this tip last week... This is exaclty what I didn't do! I've only driven mine once and I need to torque it to specs anyway so i'll try this. Thanks for the tip.
......i have new springs all around.............i took her for a little spin, hoping that she would settle in.............nope
mudbilly said:it only took a 2 hours to do the other side and have the car sitting back on the ground..........and the reverse eyes put her right where i wanted the stance............on the DRIVERS side only
...the car STILL sits 1-1/2 inches higher on the passangers side rear...........i have new springs all around.............i took her for a little spin, hoping that she would settle in.............nope
.........where do i go from here?????? i don't even know who to talk to about this, a frame man or a body guy
it seems that this is commen enough from the comments i've read on :SNSign: ............someone here has got to have figgered this out![]()
dennis112 said:How are the front springs? They definitely have an effect on how the rear sits..
dennis112 said:Now that you have been out for a drive, have you loosened the front spring attaching bolt and the rear shackle nuts a few turns and then retightened them? The bushings could be binding if you only tightend them while the axle was hanging.
At the front end, the lower control arm bushing is also subject to binding. Mark your eccentrics, so you don't lose your camber setting, loosen the pivot bolt, and go for a spin around the block. Having said that, I would be surprised if the front end would have that much effect on the ride height in the rear on a '73 vert, since their "frame" is so flexible.mudbilly said:they are brand new with a 1" drop
i'll try that, since it will only take a minute..........
180 Out said:At the front end, the lower control arm bushing is also subject to binding. Mark your eccentrics, so you don't lose your camber setting, loosen the pivot bolt, and go for a spin around the block. Having said that, I would be surprised if the front end would have that much effect on the ride height in the rear on a '73 vert, since their "frame" is so flexible..
180 Out said:Were your new leaf springs a good match when they went in? If you're sure that every dimension of the installation and the parts are symmetrical, then I would get busy with a tape measure and some jack stands, two sets, one to support the chassis and one to support the axle with the vehicle weight on it, and measure everything from side to side. If I came up with nothing, I would swap the springs from side to side.
180 Out said:Are the U-bolts square to the axle tubes?
180 Out said:Are the through-bolts on the spring packs registered in the holes on the axle tube brackets?
180 Out said:I would remove the shocks to see if that eliminated the asymmetry.
big time..........and there is NO WAY that I can let her know that it was your suggestion if it works. She already says that I NEVER listen to her
67topless said:This is exactly the same issue I had when I swapped my rear springs out (passenger rear side was over an inch higher). Did you torque down everything with the suspension in the air?
67topless said:That is what I did and what caused my 2 1/2 weeks of agony. Once I loosened up all the bolts and took the car for a spin (gingerly); I came back and all was level. I then torqued it all down to specs with the suspension on the ground (i.e. tires carying the weight).
Scott
mudbilly said:yep
did you loosen ALL the bolts, front eye, rear shackles top and bottom, and all 8 u-bolts ??
