Replacing Side windows (both) info??
easy job. Take the interior pannels around the rear quarter windows out and remove the small (I think 10mm) nuts and slowly peel the window out. Make sure you have all nuts (i think there is 7 per window) off before trying. the sealant should stay with the window and you may be able to reuse it. I would try and refinish a set to look like new ones before installing them.
on your quarter glass don't try to reuse the butyl tape it will only cause a leak you want to get 5/16 butyl tape (aka windshield ribbon) and put that on your new window. now the door glass will be a bigger pain because Ford uses rivets to hold the glass onto the brackets(about the same style that hold your door handles on) you will need to knock the centers out then drill the rivet out to get the door glass insulators off the track work then reassemble and use rivets or bolts to put back together (wear safety glasses I did auto glass for 5 years you never know with tempered pieces)
For the door window, you will have to remove the door panel. Here's from off the top of my head:
1) Unscrew and remove the triangle plastic panel by the mirror. (Phillips Head)
2) Unscrew and remove the plastic door handle cup. (Phillips Head)
3) Unscrew and remove the window switch panel and unplug. (Phillips Head)
4) Unscrew top screw on armrest behind window switch panel. (Phillips Head)
5) Pop off the plugs (2) on the bottom of the armrest with a small flathead screwdriver.
6) Remove the bolts (2- 10mm IIRC) from the bottom of the armrest with a socket and extension.
7) Carefully pry the door panel clips away from the door with either a clip remover or a large flathead screwdriver.
8) Pull the door panel off from the top pushing upwards after all the clips are loose.
9) Peel away the plastic so you can access the inside of the door and get to the bolts for the window.
10) Remove the bolts and vacuum all the glass out of the inside of the door.
11) Replace the window by carefully sliding it down into the door and bolting it to the slider track.
12) Replace the door panel in reverse order.
For the rear window, you will have to remove the rear quarter panel to access the bolts.
The easiest way I have found to remove the rear window is to slowly pry the molding away with a small screwdriver just enough to put a coat hanger through the glue from the inside to the outside of the car.
Then have a friend help out pulling the coat hanger (or thin wire) back and forth to saw through the glue to help get it off the car.
Hope this helps a little.
+1 on getting a new seal.
Are the windows riveted onto the slider? I haven't done this in quite sometime but I thought it was bolted the last time I did one. :shrug:
thanks for the help! so i'm guessing this is going to be a pain to do (especially with the butyl) outside in -15*C weather. ah well.... Should i get a heat gun to help seal the new butyl tape, or will it seal it when its that cold?
apply it inside then run out and pop it in just run your bolts down evenly to pull the sealant down nice and even, I used to use my cordless drill and set the torque setting fairly low. run em down a bit then get out the car and push it down some and then tighten some more till it is flat on the body. don't try to hog it all at once or it will pop the window. I almost forgot when putting on your butyl on your quarter glass put your seam(stop/start) at the bottom!!!
