  • 1994 - 1995 Specific Tech
Replacing Stereo Antenna
  • Thread starter Thread starter 94GTLaserRC
  • Start date Start date Oct 22, 2008
1 of 2 Next Last
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
Oct 22, 2008
  • Oct 22, 2008
Im looking at this part number:
F4ZZ 18A984A
Supposedly it's for the complete antenna assembly minus the rod portion. When I went to remove mine (unscrew it). It came out with only 2 threads of the stud on it. Apparently, when I unscrewed it I was really "breaking" it off.
Im trying to see if there are any step by step instructions on the best way to remove the old cable and base so I can inspect it and see if it is salvageable before ordering a new one.
Can anyone here help me with this?
Thanks
RC
J
jomull55
202
lucas, OH
Oct 22, 2008
  • Oct 22, 2008
im pretty sure they make a special drill bit that will remove the remaining threads but the name of it is slipping my mind right now.... you could just the the remnants out and put a new antennae in?
94GTLaserRC
11,178
Oct 22, 2008
  • Oct 22, 2008
That's what I want to find out before I order a new cable, but Im not sure how to get in there and remove it.
Thanks
RC
earleys94gt
1,223
Ashley, Ohio
Oct 22, 2008
  • Oct 22, 2008
For the price of a new cable and base, you may be better off just getting new ones. Less of a headache anyway. Can't imagine it would cost that much.
94-302-vert
1,947
NE CT
Oct 22, 2008
  • Oct 22, 2008
to get the base off of the fender if I remember corectly you pry the plastic off of the outside then there are 3 screws that hold it onto the fender. you need to gain acess to the inside of the fender to replace it.
Not hard to do just a PITA...
Sounds like a good time to shave the antenna...
94GTLaserRC
11,178
Oct 22, 2008
  • Oct 22, 2008
WhY would I do that??? I WANT the radio to work.
The little plastic piece and 3 screws are off already.
RC
Yobi1Kanobi
559
  • Oct 22, 2008
I tried to drill my broken antenna out and broke the bit, Putting a nice big scratch on my fender..
so dont do it that way
Bosko5.0
1,067
longwood, FL
Oct 22, 2008
  • Oct 22, 2008
Wouldn't it be cheaper to get one from a junk yard, if you are unable to remove the broken piece.
Zero Signal
2,633
Tucson, AZ
Oct 23, 2008
  • Oct 23, 2008
Seeing as though the threads are somehow corroded and otherwise just stuck in there, an EZout probably won't work. I think the junkyard is your best bet. I'd expect the cable to run somewhere in the $100 range from Ford if it's available.
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Oct 23, 2008
#10
  • Oct 23, 2008
  • #10
your getting your whole car painted soon right? why not shave the antenna and get one of the ones that goes inside the windshield like this
http://cgi.ebay.com/NEW-ON-GLASS-AM...9930949QQcmdZViewItem?_trksid=p3286.m20.l1116
94GTLaserRC
11,178
Oct 23, 2008
#11
  • Oct 23, 2008
  • #11
Actually, It's going to be several months before I get the car painted, but Couldnt I just install that ebay item now to get the radio working, THEN worry about shaving the antenna later?
That piece would save me a LOT of money compared to the $50-$60 from Ford.
Thanks
RC
urban96
3,464
Syracuse, NY
Oct 23, 2008
#12
  • Oct 23, 2008
  • #12
yeah i dont see any harm in just leaving the OEM one disconnected
94GTLaserRC
11,178
Oct 23, 2008
#13
  • Oct 23, 2008
  • #13
Do you think that antenna is "ALL" I need to work with my Sony XPLOD unit? I dont know if you need any other connectors or adapters.
Thanks
RC
Zero Signal
2,633
Tucson, AZ
Oct 23, 2008
#14
  • Oct 23, 2008
  • #14
Judging from the plug in the picture I would guess it should be a direct hookup to the back of your head unit. I tried reading about it but the giant font made my eyes bleed. I saw some blip about it being amplified (in the title too) which is either false or it comes with some kind of external power supply. I'm guess it's false by the price and giant font.
94GTLaserRC
11,178
Oct 23, 2008
#15
  • Oct 23, 2008
  • #15
I asked about the connection, and they didnt quite answer, but they DID say to make sure I have a 12v power source, which Im assuming is for the powered antenna, so it's NOT THE FONT!!
RC
95strokerPSU
986
Sacramento from Philly
Oct 23, 2008
#16
  • Oct 23, 2008
  • #16
This is your best bet. I shaved mine when I had my car repainted and have an Autoloc hidden antenna in the dash. I had one similiar to the one in the link above on my old Mustang and that worked fine. It was from Radio Shack.
94-302-vert
1,947
NE CT
Oct 23, 2008
#17
  • Oct 23, 2008
  • #17
I just bought a similar kit through summit. My problem is that the lead it came with is only ~6' long. So I will need to extend it if I choose to not put this thing inside my console.. I don't really care if my antenna works well or not as long as I can listen to my christmas lights from the road....
GTA_V6_Mustang
1,326
Miami, FL
Oct 23, 2008
#18
  • Oct 23, 2008
  • #18
Christmass lights?
GTA_V6_Mustang
1,326
Miami, FL
Oct 23, 2008
#19
  • Oct 23, 2008
  • #19
Well Rob the one in the link should work great. It does have some wires you need to hook up but thats super easy. You have one for your 12v ignition feed and 1 for your ground and then another for your radio. Relatively simple. DO IT!! lol
94-302-vert
1,947
NE CT
Oct 27, 2008
#20
  • Oct 27, 2008
  • #20
GTA_V6_Mustang said:
Christmass lights?
Yep, Christmas lights... One of my neighbors youtube'd my house last year (see my sig)... We use an FM transmitter...
1 of 2 Next Last
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
