  • SN95 4.6L Mustang Tech
resetting codes
  • Thread starter Thread starter mjjstang
  • Start date Start date Feb 13, 2006
M
mjjstang
101
  • Feb 13, 2006
Forgive me if this has been covered, I did a quick search but didn't find what I was looking for. Anyway, recently I replaced my fuel tank and during the process somehow my battery died, I may have left something on, The car wasnt used for about two weeks so maybe I have other problems, car works fine now though. Basically when I charged the battery and turned the car on, I had a check engine light, It was something to do with air fuel, I wish I wrote the codes down but I didn't and I have no way of getting them again. I cleared the codes, now my question is that since the light hasn't come back on, am I safe to assume that there are no problems, Would the light come back on if it was still a problem, or does the car still have the problem, but doesnt tell me because I cleared the code. Now if I were to disconnect the battery would the code come back. Thanks for the help.
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Feb 13, 2006
  • Feb 13, 2006
ok. well there are two type of codes stored codes and hard faults. a hard fault is the type of problem that shows up instantly when the pcm looks for that input or commands a output and nothing is there. continuous stored codes are codes that are kept in memory and are set when a fault is detected while driving or idling or whatever.
if your code was a hard fault then your all set it self checked out. if it's a continuous memory code can be set at any time and could come back on.
well to sum this up without the code we have no way of telling you what happened. next time write down the code
98blackmagic
386
wouldnt you like to know
Feb 13, 2006
  • Feb 13, 2006
M
mjjstang
101
  • Feb 13, 2006
so should I undo the battery, then the code should come back, if it is still a problem.
Mike97gt
it doe snot
10,633
Feb 13, 2006
  • Feb 13, 2006
well it will come back IF there is still a problem. it may not come back untill you drive the car around.
csledd
Official Ovary Punching Member
1,115
Paducah, KY
Feb 13, 2006
  • Feb 13, 2006
sometimes I've unplugged the battery and drove around for a week until a code came back. and sometimes a certain code would come back on as soon as I turned the car on
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
9
1997 gt Starts then dies a few seconds after.
  • 97orange
  • Aug 13, 2026
SN95 4.6L Mustang Tech Aug 17, 2026
97orange
9
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
M
05 Mustang GT With Annoying P0463 Issue
  • Machbud
  • Oct 17, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Oct 24, 2026
manicmechanic007
