Retard, advance or set to 0? TF stage 3 in a 418.
bjl95mustang
1,495
Austin,TX
Here are the cam card specs. I would like to know what affects would it have if a were to advance or retard the cam with my setup? Or should I install it straight up?
Thanks,
Brandon
418 10.5:1
Vic Jr heads
Vic jr spyder intake
95mm tb
42 lb injectors
L-maf
1.6 rr
TFS-31402002
Valve Setting Intake: .000"
Valve Setting Exhaust: .000"
Advertised Duration (Degrees): 308 intake/316 exhaust
Duration at .050 in. Lift (Degrees): 246 intake/254 exhaust
Camshaft Lift: .372" intake/.372" exhaust
Valve Lift with 1.5 Rocker Arms: .558" intake/.558" exhaust
Lobe Seperation (Degrees): 112
Intake Cam Timing at .050 in. Valve Lift:
Opens 13 degrees BTDC
Closes 53 degrees ABDC
Max lift: 110 degrees ATDC
Exhaust Cam Timing at .050 in. Valve Lift:
Opens 61 degrees BBDC
Closes 13 degrees ATDC
Max lift: 114 degrees BTDC
