Fuel Return Line for EFI Conversion
VasiliBrown
11
Hey everyone. I have an 85 mustang that was a 4 cylinder car, previous owner swapped in a 92 5.0. Currently carbureted and going to swap to efi using a Fitech kit. Trying to think of the easiest way to run a return line, hopefully avoid dropping the tank. Has anyone used the vent on top that goes to the charcoal canister? Was thinking about running the return to there. Also thought about taking out the sending unit and brazing a fitting onto there.
Third option would be could I just replace with this sending unit? Looks like it already has a return
You won't get enough flow through the vent tubing, nor would it be safe to use an old, rubber hose of that length as your return, you are running the risk of popping a line and spraying fuel somewhere potentially causing a fire.
The return style fuel system uses a pressure regulator downstream of the fuel injectors and relies on the return line to quickly carry off excess flow. If it's undersized, you will have issues maintaining proper pressure as the restrictive return will increase pressure.
For the sake of safety, please use a proper return style setup using proper metal fittings, or a AN braided line setup from front to back. Last thing you want it a fuel leak to cause a fire.
Any comment on other solutions I have brought up? I included a picture of what my sending unit looks like now, Is the sending unit I left a link to interchangeable? I wouldn't be using the same vent line, I would run a new line of appropriate size and just attach to the vent.
I'm not familiar enough with that setup to really comment. It does look like it will work as it has the pickup and return with the fuel level sender. My on;y question is if it will accepter higher flow pumps. I assume is does?
I'm used to the 86+ style tank that separates the fuel level sender from the pump pickup.
Two Words
DON'T DO IT
This is not the "Roadkill" TV show, it is your life and you car.
There are several risks involved.
(1.) The return line circuit was never designed to carry the pressure and volume that the returning fuel develops. Restriction in returning fuel volume result in the fuel pressure regulator not working. That upsets the air/fuel ratio badly and the variations of the returned fuel pressure will be impossible to tune out.
(2.) Venting the gas vapors to open air may result in gas fumes in side the passenger space and a possible fire/ explosion. The vapors in the passenger space are annoying and may produce nausea.
(3.) Any enclosed space where you park the car may stink like gasoline. Again, fire is a possibility, especially if the car shares the space with a gas fired water heater.
(4.) The in-tank fuel pump may overheat; the returning fuel sprays down on the fuel pump, cooling it by evaporation of the sprayed fuel.
(5.)The factory fuel return line uses a duck bill one way valve inside the tank; it allows gasoline to enter the tank but not exit the tank. That keeps fuel from pouring out of the tank if a car turns sideways or upside down in an accident.
Use a 5/16" steel line for the return plumbing to accommodate the returning fuel volume. The steel line will help to avoid the hazards of driving normally encountered in driving the car on public roads.
A trip to the auto salvage yard my be your best resource; the 86-93 cars all used the same return line plumbing.
@VasiliBrown
Swap in a tank from an 86-93 mustang, made for efi, no muss, no fuss, get return line for same years.
The tank may fit, but the 86 fuel tank quantity sender has the wrong internal resistance. The fuel gauge will never work correctly.
Fuel gauge sender ohms
Copied from bstrd86
86 and older are 73 ohms empty, 8-12 ohms full. '87 up are 16 -22 ohms empty 145-158 ohms full.
Fuel Quantity gauge troubleshooting 87-93 Mustangs
Revised 8-Apr-2017 to add warning about non-interchangeable fuel tank senders between 79-86 and 87-93 Mustangs.
54945
The red/yellow wire (power supply to gauge & sender) should have 12 volts when the ignition is in the start or Run position.
Troubleshooting the gauge and sender circuit:
Since the sender uses a variable resistor, sum the resistor values of 22 Ohms (empty value) & 145 Ohms (full value). That gets you 167, which you divide by 2: that gets you 83.5. So in theory, 83.5 ohms is 1/2 full. A trip to Radio Shack for the closest combination of resistors to make 83.5 ohms gets you one 68 Ohm (Catalog #: 271-1106) + one 15 Ohm (Catalog #: 271-1102) for a total of 83 Ohms at the cost of $2 plus tax. Wire the resistors in series to make a resistor pack and cover it with heat shrink tubing or electrical tape. The 83 Ohms is close enough to the 83.5 Ohm figure that it shouldn't matter. Disconnect the electrical connector shown in the diagram for the tank sender unit. Connect one end of the resistor pack to the yellow/white wire on the body side fuel sender electrical connector and the other end of the resistor pack to ground. Make sure nothing is touching that isn't supposed to and turn the ignition switch to Run. If I am correct, the fuel gauge will read 1/2 full, or very close to it. If it does not, then the odds are that the gauge or anti-slosh unit are bad.
How and why the test works…
Most of the fuel gauge failures give a stuck on full or stuck on empty as a problem symptom. Using a resistor combination that mimics 1/2 tank allows you to decide if the gauge and anti-slosh module are the problem source.
If the gauge reads about 1/2 tank with the resistor combination, that points to the sender as being the culprit.
If the gauge reads full or empty with the resistor pack in place of the sender, then the gauge or anti-slosh module is at fault.
Fuel gauge sender testing and replacement
The next steps require dropping the fuel tank and removal of the fuel level sender. Here are some useful tips...
I have done the tank removal three times, and the main issues are getting the car up on jack stands and getting the gas out of the tank. DO NOT try to do this job without jack stands. Becoming a pancake is not part of the repair process.
Pumping out the old gas:
If the old pump still works, you can use it to pump the tank out.
1.) Separate the pressure line (the one with the Schrader valve on it) using the fuel line tools.
Look in the A/C repair section for the fuel line tools. They look like little plastic top hats. You will need the 1/2" & 5/8" ones. The hat shaped section goes on facing the large part of the coupling. Then you press hard on the brim until it forces the sleeve into the coupling and releases the spring. You may need someone to pull on the line while you press on the coupling.
OR
View: https://www.youtube.com/watch?v=vRTjYAxvaCs
Use a piece of garden hose to run from the pressure line to your bucket or gas can. Make sure it is as leak proof as you can make it. Fire and explosion are not part of the repair process...
2.) Jumper the fuel pump test point to ground.
attachments\68357\
Turn the ignition switch to the Run position. the fuel pump will pump the tank almost dry unless the battery runs down first.
Some 5 gallon paint pails lined with garbage bags are good to hold the gas. The garbage bags provide a clean liner for the pails and keep the loose trash out of the gas so you can reuse it. If you decide to use a siphon, a piece of 1/2" garden hose stuck down the filler neck will siphon all but a gallon or so of the gas.
Remove the filler neck bolts and put them in a zip bag. Disconnect the supply & return lines by removing the plastic clips from the metal tubing. If you damage the clips, you can get new ones form the auto part store for just a few dollars. I have used tie-wraps, but that is not the best choice. Then you remove the two 9/16" nuts that hold the T bolts to the straps. Put the nuts in the zip bag with the filler bolts. Pull the plastic shield down and away from the tank. Once the tank drops a little bit you can disconnect the wiring for the pump & fuel quantity sender.
The fuel gauge sender assembly comes out by removing a large metal ring that unscrews from the tank. There is a separate mounting/access plate for the fuel pump and fuel gage. You are supposed to use a brass punch to tap on the ring so that you don't make sparks. Look closely at the rubber O ring gasket when you remove the fuel gauge sender.
When you install the metal ring that holds the sender in place, watch out for the gasket O ring. Some RTV may be helpful if the ring is not in excellent condition.
The tank to filler pipe seal is a large rubber grommet. Inspect it for hardening, tears and damage. At $20 from the Ford dealer, it might be a good idea to replace it.
I used a floor jack to help lift the tank back in place. You may find that it is the only time you really can make good use of a helper.
All resistance measurements should be made with the power off.
Note from bstrd86 - 86 and older fuel tank sender units are 73 ohms empty, 8-12 ohms full. The 87-93 fuel tank senders are of 22 Ohms empty & 145 Ohms full. The two different groups of sensors are not interchangeable
The yellow/white wire will show a voltage that varies with the movement of the float on the sender unit. To test the sender, set your Ohmmeter or DVM on low Ohms. Then disconnect the sender and connect the Ohmmeter or DVM to the yellow/white and black wires from the sender unit. Move the float arm while watching the Ohmmeter or DVM. You should see the reading change from 22 to 145 ohms +/- 10%.
If the Ohmmeter or DVM resistance readings are way off, replace the tank sender unit.
Use extreme caution if you do the next step. Fumes from the gas tank can easily ignite and cause a fire or explosion.
With the sender unit out of the tank and connected to the body wiring harness, turn the ignition switch to the Run position. Move the float arm and the fuel gauge indicator should move. If you are very careful, you can use a pair of safety pins inserted in the connector for the yellow/white and black wires to measure the voltage as you move the float arm. The voltage will change, but I have no specs for what it should be.
Do not short the safety pins together or to ground. If you do, you may damage the anti-slosh module or create a spark. A spark with the fuel tank open could cause a fire or an explosion.
If the voltage does not change and the tanks sender passed the resistance tests, the anti-slosh module or gauge is bad.
The 87-89 module is shown below.
This is what the 90-93 module looks like.
LRS has the 90-93 module as a standard catalog item, cost is about $160
Inexpensive anti-slosh module repair - should work on 87-93 anti-slosh modules
Copied from DrBob
I worked on an 88 Mustang today that had similar symptoms. Short version, I took the “anti slosh module” off of the back of the instrument cluster and replaced the electrolytic capacitor. Fixed it for $1.39 with a part from Radio Shack.
In an attempt to help other folks, here’s the long version.
Remove the “anti slosh module” located on the back of the instrument cluster. There was a single Torx screw holding mine to the cluster.
Find the electrolytic capacitor. It will be the largest, 2 wire component on the board. The capacitor may have a red or blue plastic wrapper on it. Mine was red.
The wrapper should have printing on it. Look for printing that looks something like this:
100uF+25V
The “100uF” tells you this is a 100 micro Farad capacitor. The “+25V” tells you the capacitor is rated for 25 Volts. Yours may be different. You may use a higher voltage part but don't use a lower rated voltage part. If you use a lower voltage part the capacitor might open later on down the road or it could be as bad as catching fire.
If you can’t find the printing you’ll need to remove the part. You have to anyway so nothing wasted. However pay close attention to the way the capacitor is oriented on the board.
One end of the capacitor will be bare metal with a wire sticking out. The other end should have some sort of insulation over it with a wire sticking out. The bare metal end is the negative end while the insulated end is the positive end. Pay attention to which end is connected to which hole on the board.
Get a replacement part. I got mine at Radio Shack, $1.39. Here’s the info:
100µF 35V 20% Axial-Lead Electrolytic Capacitor
Model: 272-1016 | Catalog #: 272-1016
See www.Digikey.com for better capacitors – these are rated for automotive use and 105° C temp which is needed to survive the hot environment found in automotive electrical circuits.
P/N 4215PHCT-ND $2.10
OR
P/N 4201PHCT-ND $2.59
Fuel tank sender unit:
Be sure to get the lock ring and a new seal if you order the tank sender unit.
@VasiliBrown
Copied from bstrd86
54945
OR
attachments\68357\
Copied from DrBob
100uF+25V
OR
Buzz killer :jester:
If you are switching to EFI you should switch to an EFI retrofit like suggested....Its the easiest way and for any fuel gauge inconsistencies theres converters for that..
Good Luck
@VasiliBrown
Copied from bstrd86
54945
OR
attachments\68357\
Copied from DrBob
100uF+25V
OR
1985 body, 1990 engine, if I read it correctly the tank/pump/sender from an 1986 should work just fine.
