Rev limiter like symptons at 3k?
Chris6050
188
Nazareth, PA
Not all the time, but most of the time, my car acts like it's hitting the rev limiter around 3000-3500 RPM. It just bucks, kind of misfires and just won't go any further then 3k-3500, I'm forced to shift. I know it's not the tach being off because I have an aftermarket tach. I heard that it might be the EGR valve, I changed that, but it didn't help. Could it be the fuel filter? Anyone know what it could be? Thanks for any help.
-Chris
Like he said, check all the wires and plugs. If all the plugs look clean, and none of the wires are cracked or burn to create arcing then try the fuel filter. Worth a try since they are so cheap. My bet is one of those 2.
Chris6050 said:
Looks like I'll try the fuel filter. Is it hard to change? Thanks.
-Chris
So you have never changed it? I would start there. It probably needs it even if thats not the problem.
grrrrrrr said:
you're gonna need a special tool from autozone to get it detached from the hose though...
No special tool, just pry the plastic clips out with a small screwdriver.
the fuel system is only pressurized when the car is on, other wise the gas goes back to the tank, it doesn matter either way if the tanks empty or full, there may still be a little spillage but not a whole lot
Yeah I think that it did. I've taken it up way past 3k a couple times since I changed it and it doesn't do it anymore. Although knowing my luck, now that I've said it's fine, it will probably start acting up again the next time I do it.
were is the fuel injection wiring harness gruond and weere is the best place to ground the motor? im having bad breaking up problems aND IM ABOUT TO HAVE A NERVOUS BREAKDOWN....LOOL............I JUST WANT my car tyo run right just got done Heads cam intake injector MAF meter instal and they car wil run ok sometmes and then itll break up erall bad other times
i moved my ground strap so maybe thats teh problem?????
Did I call it or what? Today, took it up to about 3500, same problem again. This is driving me nuts. I drive my car like a grandma most of the time and it runs fine, but I just want it to run right the few times that I am actually racing around.
How do I check my timing? I've never done it before. Also can someone give some more info on the eninge ground straps and fule injection wiring harness? I know I have a burnt valve, could that be effecting it? Thanks.
