Rev Limiter?
  • Thread starter Thread starter gofast_beloud
  • Start date Start date Apr 27, 2005
G
gofast_beloud
35
  • Apr 27, 2005
i have a 91 coupe. my throttle stuck open a couple times and i posted a thread wondering what kinda of damage it did. people said that mustangs have a factory rev limiter. i dont think so myself, but if anyone could let me know that'd be awesome.
G
gt90stang
568
  • Apr 27, 2005
gofast_beloud,
Yes, it has a built-in rev limiter in the PCM (PIP based) it is either at 6250 or 6500 RPM, depending on whom you believe. It is pretty nasty sounding when you hit it, I have and didn't like it (thought I blew my motor) so I implemented a half fuel rev limiter in my Tweecer RT tune to soften the limiter effect, it just cuts fuel to half the cylinders and is way better than using the PIP rev limiter.
Don
HISSIN50
34
129
Apr 28, 2005
  • Apr 28, 2005
yep. everything i have read (i am not as savvy as Don) says 6250. i would note that many a factory tach is off, so you can see an indicated 7K RPM or over before you might actually splatter against the limiter.
I am envious of Don's TwEECer (Don, my 94 could REALLY use you. ), but you can also run an aftermarket ignition and set it to cut spark around 6K (better to lose spark than fuel).
good luck.
squeeeg
1,905
Michigan
Apr 28, 2005
  • Apr 28, 2005
The factory limiter, like stated above, is 6250. The only way to get rid of it is get a chip for the computer. With the throttle getting stuck that is where it was bouncing. It isn't good for your engine to do that but you probably didn't do any major damage either.
T
tomabram
Banned
Apr 1, 2005
66
  • Apr 28, 2005
The rev limiter is there to PREVENT engine damage. If the motor is in good shape then you wont hurt it. Every car from Ford, GM, chrysler, to ***. and German all have rev limiters.
N
Niks93GT
47
  • Apr 28, 2005
Yep, they all got rev limiters. Raced a C5 vette tonight and heard it pop the limiter in 1st.
Nik
HISSIN50
34
129
Apr 28, 2005
  • Apr 28, 2005
i know i would not want to be running at WOT and have the puter start shutting down fuel to various cylinders. the limiter is to prevent parts from flying out of the motor, IMHO. a much better way to PREVENT engine damage is a spark limiter.
dcarlson
128
Long Island, NY
Apr 28, 2005
  • Apr 28, 2005
Actually the factory limiter is much easier on the engine. It shuts the fuel completely OFF: No misfires, no raw fuel dumped in the exhaust or on the hot exhaust valves, no backfires, no lean cylinders either. The fuel is not lean, it is off - big difference.
Not like I do it often, but over the past 15 years I've probably hit the limiter a dozen times or two with no damage.
O
injectors keeping up?
  • optionizerSS
  • Apr 4, 2025
2005 - 2014 S-197 Mustang -General/Talk- Apr 4, 2025
optionizerSS
O
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
