Reverse light connector
HISSIN50
33
129
Howdy again,
Another quick question. Does anyone know where we can find an inexpensive T5 reverse-light-switch pigtail (for a 94-95 T5)? The poles on the switch are so close together that ring terminals are iffy (and I'm not sure what size the threads are on the switch. If someone knows this, I'm set).
I read that the push-on terminal for a Fox III starter-solenoid-interlock circuit slide on nicely but I'm not sure that we can even buy those.
Any one have any ideas (I'm down with creative ideas too). I won't tell you what I have done right now.............. :(
Thanks.
For creative ideas:
I've heard of guys using female bullet connectors (often used on car stereo installs) pushed onto the studs.
There's nothing special about the 90° plug on the starter relay. You could probably pick one up at a RV/Trailer parts shop.You just have to match the stud size.
If it's the same design you could splice a pre-94 plug onto the harness.
If you're fortunate enough to have a 94-95 in a salvage yard...
FWIW the studs on the switch I have here look to be around a size 10-24.
