Ok. First off I want to ask if my car is suppose to have a reverse rotation water pump or not? I have a 92 LX HO 5.0. I was always under the impression that all the HO's were reverse rotation water pump. Second, what exactly is a reverse rotation water pump? I know the pulley turns the opposite direction from every other pulley on the motor and that the coolant flows in reverse but does it flow through the heads then through the block or does it flow through the block and then through the heads? I am having some weird cooling issues with my car and if I better understand how the cooling system works it will help me to diagnose it. Thanks
