  • SN95 4.6L Mustang Tech
revlimiter/transmission question
  • Thread starter Thread starter yellerstang
  • Start date Start date Nov 28, 2010
Y
yellerstang
42
Northumberland County, Pa. (Central Pennsylvania)
Nov 28, 2010
  • Nov 28, 2010
I have a 2000 GT automatic convertible. All stock, except for a Flowmaster cat back system.
Here is my question... When I manually shift this at about 5400-5500, the shift sometimes delays long enough to hit the revlimiter, which looks like around 6050 or so. I have only run this car a few times, so I am still learning how it acts when manually shifting vs. automatically shifting. Obviously, its more fun to manually shift it.
Is there a way to set this up so it will want to shift just slightly earlier, or, would I be better off to get it tuned to bump up the revlimiter rpm a little?
Should I just shift it at 5200 and let it do its own thing?
Does anyone know what the stock shift points are in this car at full throttle?
I dont have a programmer yet, but will be buying one in the spring. Thanks.
E
Everett
22
  • Nov 29, 2010
rev limiter is 6250 and leave it there....ford knew what they were doing when they built the motor
Maxpowers
859
Pittsburgh, Pa
Nov 29, 2010
  • Nov 29, 2010
Leave it in drive, or get a stick car.
Y
yellerstang
42
Nov 30, 2010
  • Nov 30, 2010
info
I called CJ Pony in Harrisburg, Pennsylvania and spoke with one of their guys about this issue.
Apparently the shift points are adjustable with the hand held tuners, like the SCT. You can move the shift points up or down on the rpm band. Soooooo..... I can move the shift point a little bit lower and keep the rev limiter at the stock setting. Also, I can firm up the shifting a little bit, the SCT allows that also, along with the other little changes that the SCT allows.
I'd say that I need a tuner, right after the 4.10s go in.
Thanks for the replies, much appreciated.
Jess
Y
yellerstang
42
Nov 30, 2010
  • Nov 30, 2010
revs
Yep, sounds like good advice. Thanks.
merc123
420
North GA
Nov 30, 2010
  • Nov 30, 2010
I wouldn't recommend 4.10's with an auto. Too much gear.
Y
yellerstang
42
Nov 30, 2010
  • Nov 30, 2010
410s
I am new to Mustangs. I had an IROC for 17 years. So, I am now faced with a learning curve, I am trying to figure out what I want to do to this car and how it will perform it's duties as a cruiser. I am not a racer. Stoplight fun once in awhile, but I have never drag raced at the track.
My Mustang comes out in good weather, top down, music jammin, and me and my wife grinning from ear to ear. Its fun.
I have read over and over that 4.10 gears are the way to go with an automatic. I have had a few well known Mustang tuner guys tell me the same thing, however, I need to live with the gears not as a racer, but as a cruiser.
I want performance, neck snapping tire squealing second gear rubber on the road. I really dont much care about gas mileage. I get 22-23 now, when I am cruising at 65-75 on the interstates. If it drops to 18-20, I dont care.
With my 3.27 stock gears, the tach reads about 2000 rpm at 68 mph. I dont know just how much the 4.10s will change this. My next search is for someone who has the 4.10s, maybe they can enlighten me on this.
It is not uncommon for us to hop in the car and take a 3 hour cruise, so I have to be sure that the gears are what I want. I will have to live with it.
Thanks for your comment, I am looking into the gears and havent decided.
Jess
merc123
420
North GA
Nov 30, 2010
  • Nov 30, 2010
About 2500 with 4.10's
Here's a calculator and gear ratios:
Ford Mustang: Mustang Tech: Calculators & Decoders: RPM Calculator
2000 Ford Mustang Specifications
I made a mistake. I was thinking blower setup with the 4.10's. Get the 4.30's with the auto because then it'll be the same as a 4.10 with manual tranny
Flghtmstr1
572
Springfield, PA
Dec 1, 2010
  • Dec 1, 2010
For what it's worth, I have 3.73s in my automatic, and I liked them when I was naturally aspirated, especially on long highway drives. I think the 4.10s would have been excessive for highway use. With a blower, even the 3.73s are too much, and I'll probably have to step back to 3.55s or even the stock 3.27s.
Y
yellerstang
42
Dec 1, 2010
#10
  • Dec 1, 2010
  • #10
373
The 3:73 gears arent really much deeper than the 3:27 ratio. Was that a worthwhile expense?
I havent decided yet, I am hoping to drive or ride in someones Mustang that has the gears... see first hand whats up with rpm, noise, and performance.
Its gonna be 3:90s or 4:10s, I havent decided yet. I have some time to decide on this, Im not doing a gear change until Feb. or March.
Flghtmstr1
572
Springfield, PA
Dec 2, 2010
#11
  • Dec 2, 2010
  • #11
I got the gears for free, so I can't comment on how worthwhile it was lol. I noticed a difference, but I would imagine 4:10s would be better in that regard. You have to understand that it's going to be a compromise, and if you intend to spend a lot of time at highway speeds, 4:10s may be too much, but you'll be leaving some performance on the table if you go with 3.73s. It's all about your priorities and goals for the car.
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
K
Electrical 2000 GT Intermittent Engine Shutdown In Motion - DTC U1262
  • kenster1092
  • Apr 13, 2026
SN95 4.6L Mustang Tech Apr 24, 2026
squeak93
C
1992 LX 2,3, automatic problems, oil dissapears.
  • Carpimp
  • Aug 10, 2025
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Aug 10, 2025
General karthief
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
