  • SN95 4.6L Mustang Tech
Rich and Lean
  • Thread starter Thread starter nic01scgt
  • Start date Start date Jul 14, 2005
N
nic01scgt
48
Saint Louis
Jul 14, 2005
  • Jul 14, 2005
Well I took my car up to 1st Capital 4WD today to get dyno tuned and got some bad news. While on the dyno the car would go from rich to lean then rich then back to lean. He also said he found some gas in the crankcase. Could this be from a bad injector leaking or what. Do you guys have any ideas?
Lons2001GT
75
  • Jul 14, 2005
Too many possiblilities without looking the car over in person and looking at the data log info from the dyno session.
flashstang04
154
Wichita Falls,Tx
Jul 14, 2005
  • Jul 14, 2005
I though this thread was about a rich skinny chick...oh well,
really, the guy doing the dyno should have been able to tell you something by the data log.
csledd
Official Ovary Punching Member
1,115
Paducah, KY
Jul 15, 2005
  • Jul 15, 2005
you got a s/c on there? has that been tuned? what kinda numbers did you put down?
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Jul 15, 2005
  • Jul 15, 2005
they could'nt figure it out on the dyno? then we have no chance of figuring it out here.
N
nic01scgt
48
Saint Louis
Jul 15, 2005
  • Jul 15, 2005
I just thought I'd ask you guys to see if anyone else had the same problem. I left the car there over night so hopefully tomorrow he'll have some answers for me. He said he thought it might be a bad injector because there was gas in the crankcase so we'll see. And yes there's a supercharger on there but I don't knwo the numbers
N
nic01scgt
48
Saint Louis
Jul 15, 2005
  • Jul 15, 2005
Well if anyone was wondering what was wrong it was my fuel pressure regulator and my throttle position sensor. I still don't know how that translates to gas in the crankcase? Also what is the normal output for the FPR? He said mine was fluctuating for 10-12 lbs. Could this explain the rich to lean? Also he said my TPS was giving out 1.2-1.3 volts and he said that was bad and I needed a new one of those. Anyone have any comments?
Superhereaux
chicks make me feel inadequate
538
South Texas
Jul 15, 2005
  • Jul 15, 2005
not too sure on the fuel pressure, don't know stock specs
as for the tps, voltage should vary from around .8 (tb closed) to around 4.5 (wot)
if you have a voltmeter you can check for yourself
hotmustang331
2,967
Bastrop,TX
Jul 15, 2005
  • Jul 15, 2005
Gas in the crank case? How the heck did he come to that conclusing? Did he check your oil, or drain your oil? You need a tune....but it could be the TPS thing that messing you up.
Mike97gt
it doe snot
10,633
Jul 15, 2005
#10
  • Jul 15, 2005
  • #10
fuel in the crankcase.. are you sure this thing is firing on all cyl. a random misfire can cause the a/f too jump all over the place due too the unburned oxegen from a misfire. the sensor does not pick up the fuel only oxegen so it sees this as a lean condition..
N
nic01scgt
48
Saint Louis
Jul 16, 2005
#11
  • Jul 16, 2005
  • #11
Well I'm guessing since it's been running rich for awhile then my plugs are fouled right? I'm going to change them when I get the car back.
triggz
1,218
Gadsden, AL
Jul 16, 2005
#12
  • Jul 16, 2005
  • #12
the stock fuel rail pressure should hover around 40psi regardless of throttle, 36-50 is average fluxuation.
R
Microsquirt tune for stroked 351W in a foxbody
  • roldy
  • Jul 26, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Oct 25, 2026
roldy
R
'04 V6 running rich excessively on both banks
  • 04DSGVert
  • Oct 26, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Oct 27, 2025
04DSGVert
  • Gulftown980x
  • Jul 29, 2026
squeak93
F
Trouble Shooting Sudden Shift of AFR at low RPM
  • Farva_84
  • Jun 6, 2025
SN95 4.6L Mustang Tech Jun 8, 2025
Farva_84
F
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
