Ride Height Change Effect Alignment?
  • Thread starter Thread starter grego37
  • Start date Start date May 5, 2005
G
grego37
576
Fresno CA
May 5, 2005
  • May 5, 2005
1968 mustang
If I change my ride height by cutting partial coil, I was told I would need an alignment job.
Which area of alignment changes during lowering
Camber?
Caster?
Toe?
or?
thanks.
C
C0V3R
524
Australia
May 5, 2005
  • May 5, 2005
All of the above, by differing degrees depending on the nature of your setup.
By lowering it you would increase the amount of flat level camber, and affect the toe in. This is because of the way that toe is affected in mustang steering during compression/jounce (i.e. bump steer). Caster I am not so sure about however it wouldnt surprise me if it was also affected.
In summary, get an alignment after you are happy with the ride height.
XXBULLETSXX
301
Kannapolis, NC
May 5, 2005
  • May 5, 2005
I have lowered about 10 cars and every one of them has had the camber changed because of the change in ride height. Now I know when the camber changes that affects the other things as well, but the camber is the thing that is affected the most.
That's what my experience has been. Bottom line get an alignment if you like your tires.
G
grego37
576
Fresno CA
May 6, 2005
  • May 6, 2005
when you lowered the car, and the camber changed,
did it change to more neg. camber or more pos. camber??
which way did it move?
XXBULLETSXX
301
Kannapolis, NC
May 6, 2005
  • May 6, 2005
In every case, negative.
sonicsilver88
new jersey
May 6, 2005
  • May 6, 2005
the top of the tire moves in cause you change the pivot point. this changes the way the tire contacts the ground... youll ware the insides of the front tires out pretty quickly
Fox Alignment Suggestions
  • PonyGTrider
  • Jul 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 13, 2025
PonyGTrider
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
Tightening upper control arm bushings at ride height dilemma… need some help
  • AnthonyA1234
  • Dec 27, 2024
  • 2 3
6K
Fox 5.0 Mustang Tech Feb 27, 2025
General karthief
