Ring Recommendation??
  • Thread starter Thread starter kett3023
  • Start date Start date Dec 12, 2004
K
kett3023
philadelphia, pa
Dec 12, 2004
  • Dec 12, 2004
Hey Everyone!
I am rebuilding a block, and I'd like to hear your opinion on what brand of rings i should get?
Basically here's my engine so far:
10:1 flat top pistons 30 over
Small chamber heads, ported (about 63cc)
1.94" intake and 1.6" exhaust valves
roller rockers, comp cam 280deg.
well thats the project so far, i have an intake from a 83 mustang, which is about 600 cfm, but I think i may go street avenger for better flow and single plane. I have a holley 600 cfm for the top.
this is gona be fun!
any ring brands you guys like the best?
M
manpowermustang
228
Milwaukee, Wi
Dec 12, 2004
  • Dec 12, 2004
Whaaaat?! I think you have alot more to worry about if you are serious on building a motor, not some f*** rings. I think Ive heard it all.
Dont wanna be rude tho, sorry if I sound that way.
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Dec 12, 2004
  • Dec 12, 2004
Ummm, rings are an important component. Bad rings, your going no where.
I have heard that the Total Seal gapless series are pretty good, the "race" one's will wear fast but the street series will last you a while. The whole reason my engine is being rebuilt is because of bad ring seal. I will probally go with the total seal rings, suposed to have 1% or less leakdown, which is a hell of a lot better than the 30-50% my motor had.
giddyup306
3,041
Dec 12, 2004
  • Dec 12, 2004
Total seal gapless. They're pricy but well worth it. I paid like $250 for mine. Don't get the file to fit ****. It will take you all day to file those SOB's. Especially if your building a nitrous motor.
EMW150
2,020
Roaring Spring,PA
Dec 13, 2004
  • Dec 13, 2004
I like good old moly coated Speed Pros - file fit. That's all I'll use. I've thought about trying the Total seals in the past but I've talked to too many that had nothing but problems with the gapless.
giddyup306
3,041
Dec 13, 2004
  • Dec 13, 2004
The only thing about molly rings is that they are designed for high debris applications such as hummers (not the civilian ones) and farm diesel equipment.
Ford_Racing
55
Portland Texas
Dec 13, 2004
  • Dec 13, 2004
Total Seal Gapless are the best.
90mustangGT
2,773
17
89
Dallas, GA
Dec 13, 2004
  • Dec 13, 2004
I am probally going with gapless Total Seals on mine. What's the point of high flow heads, and intakes when your just going to loose a large percentage right by the rings.
EMW150
2,020
Roaring Spring,PA
Dec 14, 2004
  • Dec 14, 2004
Just because they're gapless doesn't mean you aren't going to get blowby. I've talked to fellow racers at the track who have tried the gapless rings in several different motors and lost horsepower on the Dyno and had oil consumption problems. If the second ring gap is not just right it'll cause the top ring to flutter due to trapped combustion pressure between the top and 2nd ring. So yep, they looked awesome in a leak down test but didn't put up the numbers. For as many guys I know that have used them probably half liked them and half won't use them again so I've never took the chance on them. I just run the Speedpros with a straight tight gap. My engine may not put up awesome leakdown numbers like the gapless would, but it puts up the horsepower numbers and doesn't burn oil.
rd
3,316
63
109
Ocean Springs MS
Dec 14, 2004
#10
  • Dec 14, 2004
  • #10
Speedpro, moly coated, or use the recommendation of the piston manufacturer.
I have used two sets of these, one now has 95,000 miles, well over a hundred passes and a 100 shot and seems fine. I did use pre fit ones both times, seems to work.
I think the chrome faced rings are the ones primarily intended for the industrial applications, not moly. The moly function is to improve oil retention. The chrome is more resistant to damage from abrasive particle ingestation.
D
First post 289 rebuild question!
  • Ddyer2868
  • Nov 24, 2025
Classic Mustang Specific Tech Dec 5, 2025
rednotch
9
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Engine Forged flat top pistons from 5.0 fit a 351 build?
  • PonyGTrider
  • May 22, 2025
2K
Fox 5.0 Mustang Tech Feb 1, 2026
PonyGTrider
