Shakerhood
20+ Year Stangneter
That is what I mean. Pull rivets are a pain in the @$$. I would prefer to buck rivets, and I really hate bucking rivets...
What ever size you need... I would guess 1/4" would be close![]()
The beauty of doing custom stuff is that you get to make it up as you go...![]()
jason
All the holes that the rivets go in, i can put carriage bolts in those holes.
I'm not putting the bolts into anything it shouldnt be right?
Also 1/4 Diameter but what about the length?
Plus how do you put in carriage bolts?
You need the nuts to go under the bolt.. u cant get your hand under where all the rivets are suppose to go. so that would'nt work.
If it isn't possible to get to the back side of the bolt, then the carriage bolts won't work.
I guess I'm not sure what rivets are being installed...
Shaker,
THose are the ones I have right now.
Have you already pulled the Rivets and they are still loose? You can always put a washer on the end before you pull them.
A Picture of what you are doing would help, I looked in the Service Manual on installing the Nose on an LX, they list the Rivets as P/N 388664-S 100, it calls for 17 Rivets for the install.
YEs the old rivets have been drilled out, and the new ones that would fit were put in. I only have a few in right now because most of the rivets have a problem staying in they just dont fit in their right..
That's why i said i thought i need bigger rivets... like 5/16" or 3/8"
