road noise in my speakers
banks98stang
57
ok so i have a pioneer deck with a 10 and amp in my stang. when the cars off and i turn the radio on with out the car started its fine . but once i start the car the speakers distort. i ran a better ground for my stereo and im still having this problem can any one help
i had a problem like this when i had my cavalier before drivin the stang. i had a amp hooked up but if you unhook the amp and run the speakers through the deck it'll work fine, it was wierd but once i researched and what not i had the amp hooked up and i unplugged my alternator while running the car and the stereo worked fine, never really found my problem tho so i just used the mono switch on the amp and ran mids and tweeters
it might be a problem with powerwire, spark plug wires give off alot of electromagnetic fields these fields are probably coming in contact with your power wire, they make things to supress these sounds, (diodes). or you can try to run your wiring in a different route. somewhere in your system you are picking up EMIs you need to just reroute your wiring or put some sort of supressor in circuit.
