  • 1994 - 1995 Specific Tech
Rocker adjustment
  • Thread starter Thread starter str8stang036
  • Start date Start date Mar 4, 2009
str8stang036
1,382
Miami
Mar 4, 2009
  • Mar 4, 2009
I remember reading somewhere that new rockers need to be tightened like 1/4 or 1/2 turn after the engines been running for some miles. I need to do this, as I haven't done it before.
What specifically is the amount of tightening needed? They are Crane 1.7, no noise from them at all.
Killercanary
The car that set the bar.
Altoona, PA
Mar 4, 2009
  • Mar 4, 2009
On a race engine 1/4 to 1/2 is good, on a street car 1/2 to 3/4 is good. I usually go 5/8th of a turn on my setups to ensure they are quiet. I can't say that I have ever re-adjusted mine after running them for some time though.
T
Touring23
294
Washington
Mar 5, 2009
  • Mar 5, 2009
Wait, Crane 1.7s? Pedestal-mounts, right?
If they are pedestal-mounts, just torque them down to spec.
I've never heard of
Something's not right (maybe my misunderstanding).
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Mar 5, 2009
  • Mar 5, 2009
I've never heard of
That is true if EVERYTHING is still OEM
What if the block or heads have been cut
What if the hg used is thinner or thicker
There could be many things ... non stock ... one might not know about
on a car that is now 10 plus years old
Grady
ShortThrow50
923
Pa
Mar 5, 2009
  • Mar 5, 2009
The rockers should have locks. you cant adjust them the way you normally do during a build and then go back and another 1/2 turn. Your gonna wind up having all your valves stuck open. Set them at a half turn to begin with and lock them. done
str8stang036
1,382
Miami
Mar 5, 2009
  • Mar 5, 2009
yes, 1.7 pedestal. thanks everyone
T
Touring23
294
Washington
Mar 5, 2009
  • Mar 5, 2009
Grady
Pardon me for being dense, but it sounds like we're talking about two different things:
The OP is asking about re-torquing pedestal-mounts after a few miles, if I read that correctly:
Whereas some of these posts are alluding to properly setting lifter preload during the initial assembly, which in my mind would be a different chore. Apologies if I'm misunderstanding, I have never added 1/4 to 1/2 turn to my pedestal 1.7ss after a few miles.
str8stang036
1,382
Miami
Mar 5, 2009
  • Mar 5, 2009
I guess I had heard wrong. Good thing I asked.
VibrantRedGT
"STANGNET'S PENGUIN SMACKER"
424
154
Boca Raton, Florida
Mar 5, 2009
  • Mar 5, 2009
For Ped. mount rockers that make zero noise I wouldn't touch them. It means you've done them right. You can go back in and make minimal turns but I'm sure it will likely give you noise, I'd pass.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Mar 5, 2009
#10
  • Mar 5, 2009
  • #10
My Bad ... My Bad
Yes he did say ... make a change ... AFTER ... the initial adjustment
With peds and the typical hyd roller cam
If you did it correctly the first time .....
Like Joe said above ... I'd leave em be
Grady
str8stang036
1,382
Miami
Mar 5, 2009
#11
  • Mar 5, 2009
  • #11
They will be left alone then.
Crank no start on a turbo and cammed pushrod 5.0
  • 1630stri
  • Sep 2, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 16, 2026
Qtrhrse23
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
D
Rockers, lash adjusters and timing: help with parts (4.6 2v)
  • dvigAtel
  • Nov 1, 2025
  • Other Auto Tech
Other Auto Tech Nov 1, 2025
dvigAtel
D
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
