Rocker arm help needed
  • Thread starter Thread starter 87redgt
  • Start date Start date Jan 20, 2011
87redgt
32
Richmond, CA
Jan 20, 2011
  • Jan 20, 2011
Im nearing completion of my 306 build but need some help. I want to swap over my stock stamped rockers from my old heads to my new gt40 heads. is it as simple as unbolting them and putting them on the new heads, and torqueing down to spec? is it possible to do this with the heads off of the car or must the new heads be bolted down with the pushrods installed on the block?
stykthyn
5,232
2,652
223
gainesville
Jan 20, 2011
  • Jan 20, 2011
Heads must be installed. Start with 1 at tdc and tq that rocker down. Move #2 to tdc and tq so on and so forth. Be sure to put plenty of assembly lube on the rocker fulcrums.
87redgt
32
Richmond, CA
Jan 20, 2011
  • Jan 20, 2011
torque down to how many ft. lbs? and also is it ok to re-use the lifters if they aren't put back in the same order as before? i'm also using my old cam.
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
A
Help ID - Turbo GT, SVO differences
  • aldoelmalo
  • Jun 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 2, 2026
aldoelmalo
A
9
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
J
MEED HELP!! 86 mustang
  • Jacob0121
  • Jan 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
CAMTWO1070
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
