Rocker Arm play?
  • Thread starter Thread starter fox racer
  • Start date Start date Jul 3, 2007
fox racer
577
Staten Island, NYC
Jul 3, 2007
  • Jul 3, 2007
I'm reassemblying my engine, and I got up to the Rockers (Cobra). I torqued them down (25 ft/lbs), but I still have a little play in a few of them. Not side to side, rather front to back (as in valve to pushrod). Is that normal, or do I have a big problem? It's only slight play in only 3-4 rockers.
84fiveohore
23
york, pa
Jul 3, 2007
  • Jul 3, 2007
are your rockers adjustable? if so you probalby need to set ur valve lash. 25lbs just aint gonna cut it
fox racer
577
Staten Island, NYC
Jul 3, 2007
  • Jul 3, 2007
They're pedastle mount, the only adjustability is found through shims.
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
Jul 3, 2007
  • Jul 3, 2007
are you using factory pushrods? they could be bent.
cenok is family
1,409
69
79
Norman, Ok
Jul 3, 2007
  • Jul 3, 2007
did you get to zero lash before you torqued them down? yeah you might need to shim those rockers.
A
aNotchAbove
75
  • Jul 3, 2007
In addition to the above, did you work on each cylinder's rockers when it was at TDC?
88mouse
630
Mooresville nc
Jul 3, 2007
  • Jul 3, 2007
i had the same probablem with mine. shim's will only make it have even more valve lash. the pedistal that the rockers sit on are to tall i had a few sets laying around and found some shorter ones to get mine right. the only way i know that you can fix this is to grind some off of your or find a set that is shorter.
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Fox Suspensión Noise
  • PonyGTrider
  • Nov 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 8, 2026
PonyGTrider
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
